TintDude Window Tinting Logo
      Welcome Guest ( Log In | Join )
Remote Start on 2004 Saturn VUE
Reply to this topicStart new topic
*AkDale *
Comment Jan 9 2005, 09:41 AM
  #1
Hi all----
What a wonderful forum!!
I live in Alaska and have been searching high and low for a wiring diagram for the 04 VUE.
Also the where to locate the wires instructions.
I know they exist, but can't find them anywhere.
Any words from the wise on brand of remote start/locks to get?
Anything to watch out for while installing in the VUE?
Thanks,
Dale
Go to the top of the page
+Quote Post
kccartint
Comment Jan 9 2005, 10:19 AM
  #2
Here ya go.
12volts orange (x2)(common 30A) + ignition harness
Starter yellow + ignition harness
Second Starter N/A
Ignition pink + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory orange + ignition harness
Second Accessory brown + ignition harness
Keysense lt. green - ignition harness
Notes: The lt. green key sense wire at the steering column must see a ground during remote start to keep the SERVICE light from coming on. This wire is also found in pin A11, gray 24 pin plug at BCM.
Power Lock red/black + BCM, gray 16 pin plug, pin A8
Notes: The BCM (Body Control Module) is in the center of the dash behind the pocket.
Power Unlock orange/black + BCM, gray 16 pin plug, pin A7
Notes: To unlock just the driver door use a lt. green (+) wire in pin A2, gray 16 pin plug at BCM.
Lock Motor gray 5wi driver kick, door harness
Unlock Motor tan 5wi driver kick, door harness
Parking Lights+ brown + BCM, gray 24 pin plug, pin B10
Parking Lights- lt. blue - BCM, gray 24 pin plug, pin B6
Notes: This wire is only on vehicles with automatic headlights.
Hazards same as turn signal wires
Turn Signal(L) lt. blue + turn signal switch
Turn Signal® dk. blue + turn signal switch
Reverse Light lt. green + kick panel, harness to rear
Door Trigger gray/black (D), black/white(P) - BCM, gray 24 pin plug
Notes: The driver door trigger is gray/black in pin B2. The passenger door trigger is black/white in pin A12. Use both wires and diode isolate each.
Dome Supervision white - BCM, pink 24 pin plug, pin A1
Trunk/Hatch Pin red/black - BCM, gray 24 pin plug, pin B4
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm factory remote or passive
Notes: The factory alarm is programmable for Active, Passive (5 minute delay), or Disabled. Turn ignition on, press PANIC button 8 to 10 times in 5 seconds. Within 3 seconds press UNLOCK button for Disabled, LOCK button for Active, or LOCK button twice for Passive.
Factory Alarm Disarm factory remote only
Disarm No Unlock disarms with remote start
Tachometer NOT pink or red ac any fuel injector
Wait to start N/A
Brake Wire lt. blue + brake pedal switch
Parking Brake lt. blue - BCM, gray 24 pin plug, pin A2
Horn Trigger black - BCM, pink 24 pin plug, pin B2
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Immobilizer Bypass Module: Required: Yes Type: Passlock 2 Part #: 555L or 555T
Notes: The Passlock 2 wire colors are yellow, orange/black, and red/white (not used).
All information is per dei.
+Quote Post
*AkDale *
Comment Jan 9 2005, 02:31 PM
  #3
WOW,
You are awsome.
Thanks more than a million------
Dale
QUOTE (kccartint @ Jan 9 2005, 09:19 AM)
Here ya go.
Second Starter  N/A
Second Ignition  N/A
Third Ignition  N/A
Turn SignalŪ  dk. blue  +  turn signal switch
Hood Pin  N/A
Wait to start  N/A
Memory Seat 1  N/A
Memory Seat 2  N/A
Memory Seat 3  N/A
[*]243874[/*]
+Quote Post
kccartint
Comment Jan 9 2005, 03:43 PM
  #4
No problem, and dont forget to use a multi meter and not a test light.
+Quote Post
Zrok
Comment Jan 11 2005, 10:58 AM
  #5
and don't forget the passlock II is VERY particular on this car, must see key sense, and if you have a 'mistake' while installing, you are allowed (by the car) only one mishap and it will lock you out..... inot.gif i just did one last week thumb.gif
+Quote Post
spacer
Members reading this topic:
Lo-Fi Version Time is now: 21st November 2009 - 02:47 PM
© Copyright 1999-2009 TintDude.com Contact tintdude@gmail.com
