My Door panels
Guest DVSoul
Guest DVSoul
Hey guys, its my first post....yea!
(about me: I build custom fiberglass car parts...hobby)
anyway, I built (customized) a pair of door panels which were originally wrapped in vinyl. ive got the fiberglass and bondo to the point that I need to start preparing for the next phase...wrapping in vinyl.
Ive never vinylled anything yet, but I am meticulous and patient.
What is the most plyable vinyl for complex peices?
I dont expect to do Vinyl often so what is the best "spray-can" adhesive?
Should projects start in the center and work out to the edges?
I will try to post a ruff pic from their earlier stage. they are two-peice panels that I want to wrap in black.
any tips to wrapping these specific item will GREATLY be apreciated.
also I can post differant pics if you would like.
thanks
  • Replies 46
Compund curvature is tough.
Zolar had tip that states you can remove the cloth backing
from marine vinyl by brushing it with MEK and then pulling it from the vinyl.
It makes it alot easier to mold curves like that.
I'd start in the center and work my way out on that one. :lol2
I'm pretty sure you're going to have some seams on that piece.
Good luck.
Guest zolar
the MEK is awesome for removing a mesh backing from the stiffest vinyl.........marine :?
makes it stretch like crazy :lol2
3 way stretch and heat formable vinyls are avaiable from custom stereo sources like
Fishman (metra) or Select Products
you will want to have the insert piece for the recessed curve ready
to hold the vinyl down while it cures
roll on some original Weldwood Contant cement
it will stick better than any spray can
Guest DVSoul
Once the MEK is applied, and mesh removed...will the MEK need to be removed (cleaned) off with a solvent or leave the residue on the vinyl? Also, will the MEK harden if the vinyl is not used right away?
Zolar, I read your post and thats some great work. I cant tell you how long ive been searching the internet for advice on these things, thanks.
you say that MEK will also "soften" the heavy marine vinyl. But (a)will the vinyl stiffen up again if left to sit? (b) Will MEK over soften and destroy regular "Wal-mart" vinyl?
(thought...."is wal-mart vinyl & MEK any good to use?")
thanks
Guest zolar
MEK is methyl-ethel keytone
a common solvent
Lowes is my source or Sherwin Williams paint stores
It works differently on diffrent vinyls
the ones with the mesh (stiff) backing work the best
MEK brushed on will let you pull the mesh off and leave the foam and vinyl intact
...before it evaporates
it will stay pliable like skin with the back off
to get it to stick, I use a heat gun and fully dry adhesive on both pieces
I use Weldwood Landau trim adhesive sprayed through an air gun
I havent found anything that works as well for compound curves
and I despise seams
'cause I cant sew :lol2
Guest DVSoul
Im guessing that my panels have "compound curves"...Damn!
Ive GOT to do these in one peice cause seems arent an option for mee either.
Im guessing that using the heat gun, it "brings back" the adhesive properties of the glue right?
Im gonna try it.
why hasnt anyone invented "shrink-wrap" vinyl yet? heat it and it tightens to form.
Guest zolar
Im gonna try it.
[*]396011
select products has heat shrink vinyl :lol2
the adhesive works best with both pieces dried for about 15 min
the heat keeps the glue from peeling off the vinyl, and makes the bond super strong
Guest sewing_guy
That's some cool fiberglassing. We do very minor molding if we have to make a rear deck or a speaker pod.
You don't have any way of having that seamed? It's just screaming for a proper covering job with seams and contours. We're doing a tour bus right now, and the last shop that did work for the company stretched and folded corners. It looked hideous. We're cutting panels and doing french seams to match the seating and it is coming out so much nicer. It looks more upscale.
On the bus stuff we're using UltraLeather. That is very very pliable and thin and contours down into a lot of recesses. It's also very durable. But I'm going to get some MEK and try taking the backing off some of our vinyls.
    2. 7
    6. 11
    7. 11
