QUOTE (VIP tint + glass @ Mar 27 2007, 12:11 AM) [*]493758[/*]
it works on the lancer evo as well after you remove the wiper
You remove the entire rear wiper facility on those?
I can give a tip on that... Just remove the wiper and the top plate. The top (outside) gasket is bigger than the bottom (inside). So, all you need to do is get your olfa and trace around the edge of the inside gasket like you're cutting out a rear-view mirror holder. Then, shrink the film, slap it in. The film should fit nicely around that inner gasket if you trimmed properly and accurately. So, maybe a thin hairline light gap right now... However, when you put that top gasket on, absolutely no light gap at all due to it being about 1/8" larger all around than that inner gasket.
I own an Evo and have done the back glass on that thing many times just trying out new films, plus I'm a member of a local Evo club and I do all the Evo's in it, so many, many Evo's have been done and I have done this on all of them. Saves the time of removing that entire wiper facility.
