TintDude Window Tinting Logo
      Welcome Guest ( Log In | Join )
POWER SPRAYER MULTI SPRAY!
Reply to this topicStart new topic
SCSSfilmn
Comment Nov 6 2007, 10:00 AM
  #1
I have been using this sprayer(MULTI FUNCTION PS) for about 3yrs+. I found it at a local janitorial suppy store & thought that I would give it a shot. In my opion its the best power sprayer I have ever used. I used the P2's but had problems with the gaskets all the time. No more P2's for me! The multi fuction sprayer has many benifits. 1) no gasket problems, 2) high pressure with minimal pumping, 3) has a multi function head( with a nice fan spray!!
The fan spray is nice and accurate, misty & solid! Being that its a fan spray, its makes its easier to spray evenly.Much better than the P2's IMPO
I do flat glass and use the jet to blast out debris from framework when needed.
The mist is good for spraying remover to get old tint off. Less mess and a even spread.
It has a off selector too, that way there is no accidental spraying.
Has a foaming head too, have not found a use for it tint related.
Easy to use, just click rotate the head to desired spray. I have had no trouble other than the jet head getting clogged every once in awhile from slip residue. Easy to clear out the clog if its happens though. I hope someone else gives these a shot and has a much success with them as I do.
Attached File(s)
Go to the top of the page
+Quote Post
ClassOnGlass
Comment Nov 11 2007, 05:30 AM
  #2
cool is it durable or does it break when you drop it like the cheapy ones from home depot
+Quote Post
solareclipseauto
Comment Nov 11 2007, 07:34 AM
  #3
looks nice, how much do they run for?
+Quote Post
SCSSfilmn
Comment Nov 13 2007, 03:07 PM
  #4
QUOTE (ClassOnGlass @ Nov 11 2007, 08:30 AM) [*]561783[/*]
Yes, they are VERY durable! thumb.gif I have used many a sprayer, from the 5.00 Ace Hardware ones, Home Depot cheaps to the P2's that are sold by tint supply companys. This one beats them all in my book. The best feature in my eyes, is the nice even square fan that it sprays. Just right for flat glass, and gives great coverage fast. beer.gif
As for price, I have not purchased another in almost 2yrs. But, I think they were around 12$ or so at the chemical supply store in town. beer.gif
+Quote Post
HarveyD
Comment Nov 14 2007, 11:31 AM
  #5
I hope the spray tip isn't as delicate as it looks but we've ordered a couple to try out. Thanks.
+Quote Post
SCSSfilmn
Comment Nov 14 2007, 06:13 PM
  #6
QUOTE (HarveyD @ Nov 14 2007, 02:31 PM) [*]562761[/*]
The tip is durable, but I have never dropped one to find out how durable. dunno.gif
I will say the set up is strong and is not like the cheap junkers! The tip could be seen as a weak area if dropped hard on the tip. But the tip is in screw on pieces, easy to clean, easy to replace. The end is a seperate piece from the shaft. If I remember right there are other type attachmets that you can purchase for spray options , and just screw on! thumb.gif
+Quote Post
spacer
Members reading this topic:
Lo-Fi Version Time is now: 21st November 2009 - 02:26 AM
© Copyright 1999-2009 TintDude.com Contact tintdude@gmail.com
