FIRST, All you have to do is pop the sail panels off that run down next to the window. Only a couple clips hold each on They come off very easy.
The rear deck is ONLY held in with 2 plastic push in retainer things. Pull the top of the seat back near the corners and look down for the black plastic retainer. Pop it out (one on each side). I was able to grab onto it with a set of dikes, you may need a trim removal tool or a big screwdriver to pry it loose, I didnt though.
Then you can flanagel the deck up and over the seat and out of your way.
It literally takes a minute or two to do this. You have wide open glass to tint after this.
I cant believe there are only 2 little pizz ant clips holding this deck in
I am doing one monday, let me know if you guys dont understand what i am talking about and i will try and take a couple pictures.
