Nov 2 2008, 07:05 AM
#1 By "ClassOnGlass"
cleaning the rear glass QUOTE i had added a new step to cleaning my rear glass with great results... 1 st thing i do is wet down the glass 2nd thing i do is scrub it down with a dobie or a white scrub pad 3rd thing is to take you clear slammer and squeegee it from middle to left accross the glass do the left side from top to bottom the repeat from middle to right top to bottom it will take off any burs tape or stubborn dirt... 4th is to remist and squeegee down with blue or clear max it works great ilove the new addition try it and post your results big joe #1 By "SCSSfilmn" Cleaning debris with compressed air QUOTE ![]() I know there have been a few threads in the past regarding using compressed air to clean window debris. I myself use it all the time with excellent results!!! These would apply mostly to flat glass, but if there is a use for auto, it could save time and money also. In my work area there are lots & lots of older homes with wooden French panes. This was the solution I ended up sticking with. I use compressed air while dry prepping the window. (Also works great to clean/blow off trimmed silicone. (on the newer windows) In some nasty case's, I also use a rechargable small wet/dry vac.(By Coleman) It sucks up well, and its not very loud, or so powerful that it blows everything around to put more debris in the air. A two 16oz can kit with nozzels ect. for about 18.00! You can fill them with your normal tire filling attachment. Using compressor, hand pump, or at you local gas station. One cool thing, is that you can also fill them will liquids and compress it. Spray whatever |
Nov 2 2008, 08:35 AM
lets go everbody vote for your favorite yankee LOL
Nov 2 2008, 03:41 PM
holy crizzap slow voting today
Nov 2 2008, 10:35 PM
joe, i have added this step to every back glass that i do. i love it, great idea. thanks. with my lil misting tech, your blue max prep....i got some clean glasses.
Nov 3 2008, 04:10 AM
GLAD TO HERE IT SNAPPY
Nov 5 2008, 12:49 PM
Looks like Class on Glass will get it seems how both tipe start with ' #1 '
| Lo-Fi Version | Time is now: 21st November 2009 - 08:29 AM |
| © Copyright 1999-2009 TintDude.com | Contact tintdude@gmail.com |
