TintDude Window Tinting Logo
      Welcome Guest ( Log In | Join )
Alignment Register for Blind Edges
Reply to this topicStart new topic
> Alignment Register for Blind Edges, Blindsided?
lilDetails
Comment Feb 4 2009, 07:33 PM
  #1
I have done this for years.....
On vehicle windows that shift or traverse it is hard to get the "hidden" edge lined up. I began using a sharpie to make a mark on the film and the glass to align the film so that I don't push it too deep or not deep enough.
It works great on older cars like a 1968 Camaro where the rear sides roll down and you just can't see all the edges all the time but don't want to leave gaps.
Here is a picture of a 2008 Caddy Escalade door that I did today that had a "hidden" edge.
Film laid on door glass outside. Hard card the spot you want to mark to extract water.
Peel film back
mark the glass with sharpie. I use an H shape.
Quickly press film back down over the fresh sharpie mark. Mark should transfer onto the film and stay on the glass. I will remark the lines if it doesn't transfer or leave enough....
Align your mark when you are installing the film and you will KNOW where that blindside is and you will have the film right where you want it.
Film installed with mark still on. Just use rubbing alcohol to wipe off marks.
Go to the top of the page
+Quote Post
scottydosnntkno
Comment Feb 5 2009, 11:35 AM
  #2
very good idea. would it be better to use a vertical line a little closer to the edge, since it would be easier to line up just one line?
+Quote Post
TintDude
Comment Feb 5 2009, 11:57 AM
  #3
QUOTE (scottydosnntkno @ Feb 5 2009, 10:35 AM) [*]665336[/*]
That's what I do. With the window rolled all the way up, I just mark both sides (on the outside) where the glass goes into the frame with a dry erase marker. As you install you can see right where both sides need to be. thumb.gif
+Quote Post
chattint
Comment Feb 5 2009, 12:10 PM
  #4
I'm very tired today, and I think that's why I'm not getting this. After I cut my film, I roll down the door glass bout an inch, slide the film in, and roll down the door as far as needed to see all hidden edges. Squeegee away and roll up little bits at the time and work out accordingly dunno.gif
+Quote Post
TintJunkie
Comment Feb 5 2009, 12:26 PM
  #5
QUOTE (chattint @ Feb 5 2009, 02:10 PM) [*]665346[/*]
Basically he is making an "H" on the outside of the glass and the film so when he applies the film, he lines up the two "H's" to make one...at least thats how I understand it.
+Quote Post
micro-edge
Comment Feb 5 2009, 12:50 PM
  #6
I stick a white hard card into the hidden edge and look from the outside to make sure it's lined up and not overlapped.
+Quote Post
lilDetails
Comment Feb 5 2009, 06:01 PM
  #7
with the mark you don't have to "see" the outside or the actual edge. You don't have to jump back and forth to look at the edge. You don't have to roll the window down enough to see the edge. You just have to line up the mark you made and then you know the film is where you want it.
For the POS that has a door glass that won't roll down you can actually line the film up pretty close with 2 marks instead of just one and get it pretty close to the right height!
+Quote Post
Shady Sherlock
Comment Feb 15 2009, 08:07 AM
  #8
I get it...
+Quote Post
Mdog
Comment Feb 15 2009, 08:48 AM
  #9
thumb.gif cool idea
+Quote Post
spacer
Members reading this topic:
Lo-Fi Version Time is now: 20th November 2009 - 11:26 PM
© Copyright 1999-2009 TintDude.com Contact tintdude@gmail.com
