May 5 2009, 06:43 PM
here is the video of the "finish" that I do on my shrinking......
Sort of stretching the film out in the middle top and bottom. I always seem to have these fingers on top and bottom when I do my wet check. I found that if I do this little stretch shrink out then I simply DO NOT have any issues with my install having fingers pop up..... finish shrinking back glass |
May 5 2009, 07:22 PM
Cool technique dude.
| *tintgod * |
May 5 2009, 08:07 PM
QUOTE (lilDetails @ May 5 2009, 09:43 PM) [*]684615[/*] here is the video of the "finish" that I do on my shrinking...... Sort of stretching the film out in the middle top and bottom. I always seem to have these fingers on top and bottom when I do my wet check. I found that if I do this little stretch shrink out then I simply DO NOT have any issues with my install having fingers pop up..... finish shrinking back glass<br/><object width="425px" height="360px" ><param name="allowFullScreen" value="true"/><param name="wmode" value="transparent"/><param name="movie" value="http://mediaservices.myspace.com/services/media/embed.aspx/m=56939966,t=1,mt=video,searchID=,primarycolor=,secondarycolor="/><embed src="http://mediaservices.myspace.com/services/media/embed.aspx/m=56939966,t=1,mt=video,searchID=,primarycolor=,secondarycolor=" width="425" height="360" allowFullScreen="true" type="application/x-shockwave-flash" wmode="transparent"/></object> that is a new one to me.. |
May 5 2009, 10:06 PM
it looks like it takes a lot of practice
May 6 2009, 07:37 AM
Cool idea Ric!!!!
May 6 2009, 11:00 AM
May 6 2009, 12:33 PM
QUOTE (lilDetails @ May 5 2009, 08:43 PM) [*]684615[/*] here is the video of the "finish" that I do on my shrinking...... Sort of stretching the film out in the middle top and bottom. I always seem to have these fingers on top and bottom when I do my wet check. I found that if I do this little stretch shrink out then I simply DO NOT have any issues with my install having fingers pop up..... finish shrinking back glass<br/><object width="425px" height="360px" ><param name="allowFullScreen" value="true"/><param name="wmode" value="transparent"/><param name="movie" value="http://mediaservices.myspace.com/services/media/embed.aspx/m=56939966,t=1,mt=video,searchID=,primarycolor=,secondarycolor="/><embed src="http://mediaservices.myspace.com/services/media/embed.aspx/m=56939966,t=1,mt=video,searchID=,primarycolor=,secondarycolor=" width="425" height="360" allowFullScreen="true" type="application/x-shockwave-flash" wmode="transparent"/></object> for some reason the link takes me to myspace, but the video wont load. I like that idea of using a hair dryer underneath ill have to try that at some point. with the ryk I dont think im good enough to use a heat gun underneath, worries me about melting seals. |
May 6 2009, 01:15 PM
the vids working for me now, that was cool. was that a white teflon you cut into that small triangle? This has been edited by Jarrett: May 6 2009, 01:16 PM |
May 6 2009, 03:16 PM
QUOTE (fphillips @ May 6 2009, 11:00 AM) [*]684772[/*] I've tried it a couple times, and can't get it, so I guess its not QUOTE (Jarrett @ May 6 2009, 12:33 PM) [*]684799[/*] QUOTE (lilDetails @ May 5 2009, 08:43 PM) [*]684615[/*] here is the video of the "finish" that I do on my shrinking...... Sort of stretching the film out in the middle top and bottom. I always seem to have these fingers on top and bottom when I do my wet check. I found that if I do this little stretch shrink out then I simply DO NOT have any issues with my install having fingers pop up..... finish shrinking back glass<br/><object width="425px" height="360px" ><param name="allowFullScreen" value="true"/><param name="wmode" value="transparent"/><param name="movie" value="http://mediaservices.myspace.com/services/media/embed.aspx/m=56939966,t=1,mt=video,searchID=,primarycolor=,secondarycolor="/><embed src="http://mediaservices.myspace.com/services/media/embed.aspx/m=56939966,t=1,mt=video,searchID=,primarycolor=,secondarycolor=" width="425" height="360" allowFullScreen="true" type="application/x-shockwave-flash" wmode="transparent"/></object> for some reason the link takes me to myspace, but the video wont load. I like that idea of using a hair dryer underneath ill have to try that at some point. with the ryk I dont think im good enough to use a heat gun underneath, worries me about melting seals. you could also get a adjustable heat gun and turn it down so its not hot enough to burn the film but hotter than a hairdryer? just an idea |
May 6 2009, 03:27 PM
QUOTE (scottydosnntkno @ May 6 2009, 03:16 PM) [*]684839[/*] QUOTE (fphillips @ May 6 2009, 11:00 AM) [*]684772[/*] I've tried it a couple times, and can't get it, so I guess its not QUOTE (Jarrett @ May 6 2009, 12:33 PM) [*]684799[/*] QUOTE (lilDetails @ May 5 2009, 08:43 PM) [*]684615[/*] here is the video of the "finish" that I do on my shrinking...... Sort of stretching the film out in the middle top and bottom. I always seem to have these fingers on top and bottom when I do my wet check. I found that if I do this little stretch shrink out then I simply DO NOT have any issues with my install having fingers pop up..... finish shrinking back glass<br/><object width="425px" height="360px" ><param name="allowFullScreen" value="true"/><param name="wmode" value="transparent"/><param name="movie" value="http://mediaservices.myspace.com/services/media/embed.aspx/m=56939966,t=1,mt=video,searchID=,primarycolor=,secondarycolor="/><embed src="http://mediaservices.myspace.com/services/media/embed.aspx/m=56939966,t=1,mt=video,searchID=,primarycolor=,secondarycolor=" width="425" height="360" allowFullScreen="true" type="application/x-shockwave-flash" wmode="transparent"/></object> for some reason the link takes me to myspace, but the video wont load. I like that idea of using a hair dryer underneath ill have to try that at some point. with the ryk I dont think im good enough to use a heat gun underneath, worries me about melting seals. you could also get a adjustable heat gun and turn it down so its not hot enough to burn the film but hotter than a hairdryer? just an idea |
May 6 2009, 05:47 PM
QUOTE (TintDude @ May 5 2009, 07:22 PM) [*]684632[/*] Cool technique dude. Has he got tip of the week for this yet? |
May 20 2009, 10:55 PM
isnt that so cool having a method named after you.
May 20 2009, 11:28 PM
I am sure Ric will post that button....he did the other day!
May 21 2009, 11:08 PM
im just starting in this business but yeah count me in specially since im sure its a pain to maintain this site.
Jun 30 2009, 05:53 PM
Isnt that called pocket shrinking thats kinda old already i saw a guy name smokin moe do it at the SEMA show 3 years ago
Jun 30 2009, 06:48 PM
Yes lrod and smokin moe picked it up here.....3 years ago
http://www.tintdude.com/forum/index.php?sh...p;hl=ryk+shrink |
Jun 30 2009, 07:02 PM
QUOTE (sunlimitedCT @ Jun 30 2009, 06:48 PM) [*]698723[/*] Yes lrod and smokin moe picked it up here.....3 years ago http://www.tintdude.com/forum/index.php?sh...p;hl=ryk+shrink |
Jul 1 2009, 11:09 AM
QUOTE (scottydosnntkno @ Jun 30 2009, 10:02 PM) [*]698725[/*] QUOTE (sunlimitedCT @ Jun 30 2009, 06:48 PM) [*]698723[/*] Yes lrod and smokin moe picked it up here.....3 years ago http://www.tintdude.com/forum/index.php?sh...p;hl=ryk+shrink |
Jul 1 2009, 11:31 AM
QUOTE (sunlimitedCT @ Jun 30 2009, 06:48 PM) [*]698723[/*] Yes lrod and smokin moe picked it up here.....3 years ago http://www.tintdude.com/forum/index.php?sh...p;hl=ryk+shrink I can tell you that I know first hand that Smokin Moe has been doing this shrink since before I met him, and that was back in 03-04... he did not learn it from this site. as a matter of fact I Have posted things about the pocket shrink and nobody here knew waht I was talking about.... QUOTE (scottydosnntkno @ Jun 30 2009, 07:02 PM) [*]698725[/*] QUOTE (sunlimitedCT @ Jun 30 2009, 06:48 PM) [*]698723[/*] Yes lrod and smokin moe picked it up here.....3 years ago http://www.tintdude.com/forum/index.php?sh...p;hl=ryk+shrink He is also correct that Smoking Moe has been doing this shrink for quite sometime. way before any of you on this site even knew about this site! |
Jul 1 2009, 08:53 PM
Jul 2 2009, 04:51 AM
You're right Lrod, thats the way I was originally taught, then different variations have come about, and I think everyone's adapted that to their own style.
Jul 2 2009, 04:56 PM
owww hmm I think ill stick to dry shrinking lol
Jul 2 2009, 07:10 PM
OK Scotty maybe I interpretted that wrong, I'm sure you'll explain anyway.
Scotty it also slips out of your hands...
Tintwife he was refering to my post about the slippery back of the film... |
Jul 2 2009, 07:18 PM
Yea the rr would make a huge difference.. I franky it in, so it does tend to slip now and then... luckly I am as agile as a cat and can normaly catch it with no probs
Jul 5 2009, 06:34 AM
TW I will give it a try your way and see how it goes...
Jul 5 2009, 09:17 AM
Jul 5 2009, 12:30 PM
I will try it that way as well... I am always game for trying something new!
| Lo-Fi Version | Time is now: 20th November 2009 - 09:01 PM |
| © Copyright 1999-2009 TintDude.com | Contact tintdude@gmail.com |
