TintDude Window Tinting Logo
      Welcome Guest ( Log In | Join )
WD40 Triumph Blades
Reply to this topicStart new topic
> WD40 Triumph Blades
Murray
Comment May 15 2009, 11:26 AM
  #1
Some of you probably already do this but figured I would mention it. I use triumph scrapers alot of times when i am doing removals when I get finished I spray the blade with WD40, keeps them from rusting so you can get a little more use out of them.
Go to the top of the page
+Quote Post
scottydosnntkno
Comment May 15 2009, 12:45 PM
  #2
QUOTE (Murray @ May 15 2009, 11:26 AM) [*]686861[/*]
I spray a little in my olfa box. If you leave it open too long the oil on the piece of paper dries up too much, so the little extra helps
+Quote Post
TINTZEUS
Comment May 15 2009, 03:45 PM
  #3
yep. thats a good tip.
+Quote Post
Murray
Comment May 15 2009, 08:16 PM
  #4
QUOTE (Murray @ May 15 2009, 10:26 AM) [*]686861[/*]
I meant to say removals on autos, I normally change the blade before a flat glass job.
+Quote Post
clear max
Comment May 25 2009, 02:34 PM
  #5
QUOTE (scottydosnntkno @ May 15 2009, 01:45 PM) [*]686871[/*]
+Quote Post
pierce8468
Comment May 31 2009, 05:11 AM
  #6
I sray the whole pack with cr laurence lube. It has a finer spray then the wd40 so it doesnt make them stick together in the pack, but keeps them from rusting. I think I actualy have a totw for this trick from a few years ago..
+Quote Post
gramma
Comment Jun 1 2009, 12:41 PM
  #7
what olfa you guys using? carbon? rust shouldnt be an issue with ss.
+Quote Post
spacer
Members reading this topic:
Lo-Fi Version Time is now: 21st November 2009 - 05:26 AM
© Copyright 1999-2009 TintDude.com Contact tintdude@gmail.com
