May 31 2009, 12:31 PM
seems logical, i'll give it a go. Good tip!!!
May 31 2009, 12:33 PM
It works quite well
May 31 2009, 02:56 PM
U know that makes sense. But I always peel the top but my films upside down so it is the bottom corner. But the spraying part would help.
Good tip |
May 31 2009, 03:12 PM
I do that!
Good tip though it does help with a cleaner install |
May 31 2009, 04:52 PM
when I peel my FG on an adjacent window I do the same thing to reduce the dirt also
Jun 1 2009, 09:25 AM
wrong
Jun 1 2009, 09:39 AM
QUOTE (blade @ Jun 1 2009, 09:25 AM) [*]691165[/*] wrong scottydosnntknohowtodoit |
Jun 1 2009, 12:09 PM
good tip! that is how I peel rear windows on my peel board, but I dont use my board for roll ups
Jun 1 2009, 01:00 PM
I do a bit of flat glass and haven't yet damaged anyone's floor. If you put a towel(or 2) down to protect the floor from the water, it also dampens the pole hitting the floor |
Jun 1 2009, 01:21 PM
I like using the rollers, I don't usually drop them though, just start out at the ground and lift the film up if it's a ground level window.
Jun 1 2009, 02:52 PM
Jun 1 2009, 02:54 PM
Jun 1 2009, 03:49 PM
QUOTE (b7adh @ May 31 2009, 03:31 PM) [*]690967[/*] seems logical, i'll give it a go. Good tip!!! Same here |
Jun 15 2009, 02:50 AM
Cool!
Jun 16 2009, 03:46 AM
Perhaps I am missing something here... Are you removing the entire liner? If so I am going to assume that your a panel puller..
Jun 17 2009, 09:55 PM
nice tip booms i'll have to give it a shot
Jun 19 2009, 10:44 AM
Jun 20 2009, 01:49 PM
Ridin' Dirty.........
| Lo-Fi Version | Time is now: 21st November 2009 - 05:19 AM |
| © Copyright 1999-2009 TintDude.com | Contact tintdude@gmail.com |
