Then remove the bolts anchoring the child seat belt attachments.
The side pillar panels pop off from the top and pull up and out. The clip i'm holding out (in the second picture) slides up and out for panel removal. It's kind of a tight biatch to put back in though.
Then the rear deck will pop up and slide out. The sides where the seat belts run through can pop off seperately from the center of the deck.
The rear deck can't be completely taken out because there arent' slits for seatbelt removal. We just pulled it down and stuck it in the trunk while we tinted it.
