tintdude.com logo
Cleaning Flat Glass
Full Version: Cleaning Flat Glass
slonez
What are some of the ways you clean flat glass before tinting. Just checking to see if there's a much easier way someone has stumbled upon.....
TintWizard
I guess I'll be the member here to ask this question:
With 12 yrs experience ...what method are you using that is not that easy in your opinion . We'll start with that and we'll take it from there smile22.gif
windoworx
I find that using a sponge with sand in it to be very ineffective, so don't try that.
Sorry, I felt compelled.
slonez
Fair questions I guess. I probably should've clarified that the vast majority of my experience has been with automotive and not flat glass. What've I've done in the very distant past is ordinary soap and water, a sponge, a squeege and if needed a razor blade.
nautiboi73
TintWizard
OK, the sysem I've used for all these yrs is alcohol / water mixture with 4" short -handled scraper blade , then I Scrubbie it with non - abrasive pad with same mixture, then squeegee , then water squeegee, then inspect . Wiping the sides of frames throughout.
I change a bit of the technique depending if it's old wooden frames, painted, etc.
blade
Soapy water, scrape with triumph scraper, scrub, wipe edges, squeegee.
Dixie Normus
blade
(DixieNormus @ Dec 22 2004, 04:22 PM)
[*]236792[/*]
Dixie Normus
blade
TintWizard
Flaugh.gif that is a good one...someone find that pic of booga..you know the one "my internet $%^ is THIS big"
bigboyk2000
TintDude
Also, when you use the triumph scraper, try to use the same side of the blade all the time to keep it sharper and from scratching the glass. It's always a good idea to test the glass first in an inconspicuos place by listinening and feeling for a certain grit sound. If you hear that, the glass is scratching, and you should not use the blade on it at all.
VO|TRON
wet it, scrape with a triumph, wet it again and then squeegee it off and then wipe the edges. takes all of about a minute
Contact: tintdude[a]gmail.com
