quarter windows 02, 03, maxima
Full Version: quarter windows 02, 03, maxima
how do the quarter windows on a maxima come out the ones that are shaped like a half moon
you mean taking out the window?
easy, pull panel roll window all the way down the bar that goes straight down usually has maybe 2 10mm bolts take those out and at the very top of the door, pull the weatherstripping off a bit and you'll see a tiny screw holding up there. take that out. if you cant find it, try on the inner part of the door. take bar out carefully without scratching nothing take window out tint it put it back in, while your at it pull the roll up window as well. way better. hope it helps
its no big deal, once you do the first one, the rest are cake, they are all mostly the same thing, any 4 door with the quarter glass. just gotta look for that tiny screw at the top remember that.
these years ..i believe the small screw is up under the seal ..at the top of the bar that you are taking out..on the inside
