Works great but might try it with 50 watt bulbs
Tip from a newbe poster
Full Version: Tip from a newbe poster
sometimes a bit hard to see through dark tint on rear glass to cut, Not very busy today so made this out of the inner rool of film. I used two 12 volt 20 watt downlight bulbs and a cigar lighter femal socket and ten rivets.
Props to you for making a unique light out of a film tube
However, I' think I'll stick to my safer store - bought 500W floodlight that cost $15
I also used a 200w flood light but needed to keep moving it around the rear deck so i could see it through the area of film i was cutting not with handy lamp just put it in place and plug it in
a tip on using the flood light ..set it on a stool or box in the backseat..that elevates it to be level with the back window..once you do that ..you never have to move the light around
a tip on using the flood light ..set it on a stool or box in the backseat..that elevates it to be level with the back window..once you do that ..you never have to move the light around and I use 5% limo often
5% ..no problem for cutting thumb
Thanks for the tip i will give that a try
these are some of the lamps i use but find then a bit bright for my old eyes how cold is it there (vampire @ Mar 8 2005, 10:04 AM) Thanks for the tip i will give it a try. how cold is it there [*]265080[/*] -7 F which is -14 C
hahah i like the tint tube light.
That is a cool fabrication... let's market it!
would be nice to have something bright enough that you can plug into the cars cigarette outlet. i just noticed that said 12 volt.
I think that's totaly sweet!
that is a pretty decent idea.....
yeah the tint tube's cool
(Mdog @ Mar 8 2005, 09:35 AM) hahah i like the tint tube light. [*]265102[/*] mikey likes anything you can do with a tint tube.
Oww so cool ..Great idea to making a better one that everyone will want to make
we use tintek so no light needed
(striper @ Mar 9 2005, 10:21 PM) we use tintek so no light needed [*]265675[/*]
i just use a large white bed sheet and drape it across the rear deck and close the flanks of the sheet into the top of each rear door and shut it.
devil
[quote=vampire,Mar 8 2005, 09:23 AM]
Me too... im just gonna stick to the store bought version
i made one the other day
this is my set up that i posted on here about a year ago..and still works great...and it telescopes
hmmm something about that light reminds me of me for some reason
(Mdog @ Mar 13 2005, 12:46 PM) hmmm something about that light reminds me of me for some reason [*]266489[/*] The thickness of the cord attached to the light (Mdog @ Mar 13 2005, 12:46 PM) hmmm something about that light reminds me of me for some reason [*]266489[/*] yeah...i thing last time i posted that...you said the same thing..
