Tinters,
I have a question, lately I have been having a prob keeping the film from puckering on the rear defrosters on just the Lexes's any advice on how to stop this from continueing.. Thank you
Lexes rear window defrosters
Full Version: Lexes rear window defrosters
Tinters,
steel wool them down
Prep wisely with Dirt OFF,
dont be limp wristed with your squeegee only those who can spell Lexus, should attempt to tint Lexus
the puckers are a result of using too much concentrated heat. turn the heat down on your heat gun and you won't have a fukking pukkering problem.
Read tip of the week i turn on the rear defroster for about 20 minutes squegee the window down problem solved some people wil say it'll break the window but idone it for 2 + years no problem
QUOTE (tintyoda @ Mar 15 2005, 08:12 PM) Prep wisely with Dirt OFF, dont be limp wristed with your squeegee only those who can spell Lexus, should attempt to tint Lexus [*]267182[/*] QUOTE (tintyoda @ Mar 15 2005, 11:12 PM) Prep wisely with Dirt OFF,
even though im "LIMP" wristed, if the bubbles between defroster dont go away, what i do i let it sit for about an hour or less, go back to teh car and touch it up, or try heating up in areas where its not going away, patience just pure patience.
I Don't ever deal with puckers...maybe it's the film you use.
QUOTE (Total tint @ Mar 15 2005, 09:42 PM) Read tip of the week i turn on the rear defroster for about 20 minutes squegee the window down problem solved some people wil say it'll break the window but idone it for 2 + years no problem [*]267193[/*] How could it possibly break the window??? Its used on a daily basis anyways... Unless its some super powered defroster...
I had that problem all the time.. used to work at teh dealer... but I blamed it all on the film .. Hooper-pooper-Optic. That was thicker than my PPF I use.. (j/k) but not really.. Yep, they are just too damn thick. have to go back and hit them with heat.
i have the same problem. steel wooled them i even lightly sanded them. and tryed three pefectly shrunk windows trust me . the best advice on these comments is walk away turn on defrost and put it the sun cause no amount of hand pressure is gettin that stuff out.
Try Madico CH/Cool on those old a8s rears...they need fast setting adheasive and a proper shrink / lock. My every day SG/Sup will puck even with a text book shrink.Thank goodness for the new models.
