2004 malibu CLASSIC sedan
Full Version: 2004 malibu CLASSIC sedan
Can someone tell me how to remove the back deck on this car? This car has the third brake light on the back deck and it is up against the BG to the point where you can't even slide the tint in there . Other than that are there any other tips I need to know about this car? I have one to do tomorrow. thanks in advance.
Basic, Take rear azz cusion out, take rear backrest out, remove pillar panels, and whamo your there!
[quote=ninjatinter,Apr 19 2005, 07:14 AM]
Basic, Take rear azz cusion out, take rear backrest out, remove pillar panels, and whamo your there! ARe there bolts or nut holding the seat cushions ? (Peja43916 @ Apr 19 2005, 02:52 AM) Can someone tell me how to remove the back deck on this car? This car has the third brake light on the back deck and it is up against the BG to the point where you can't even slide the tint in there . Other than that are there any other tips I need to know about this car? I have one to do tomorrow. thanks in advance. I got it . Removing the rear deck was easy. Just two 13mm bolts on the backseats and they pop up and out. Pillars just pop out but carefully not to break plastic clips and rear deck just pops up after removing the 2 light bulbs for the brake light. Front roll ups had to be shrinked and it was hard cutting front rollup because the mirror is in the way. Other than that car was not too bad.
