I have a trick to share for those custom tint graphics, for those of us that are, too poor, or too picky, for a plotter.
1) Take your image into your image editing software, and blow it up to the actual size you need,
2) Export (slice) the image into 8 1/2 x 11 squares and print them out on paper.
3) Tape the seperate pieces of paper, on the back of a piece of glass.
4) Cut out your tint on the front of the glass, using the picture as a reference.
5) Move over the film, and apply a clean piece of liner, over the artwork.
6) Position the film in place over the graphic, and anchor with water.
7) Peel off the film's liner.
8) Wet with slip and pull up the bottom piece of liner, the graphic will be in place for installation.
9) squeegee out the slip gently, and let dry. and cover with a solid piece of film.
here's the result:
Click to view attachment
Try it out on your next graphic, It works on really big stuff too!
Z
