tintdude.com logo
350Z
Full Version: 350Z
expertint
Little window in back..a little hard to get to..Any tips??
Texastintchick
Devil with bad attitude
I see what you mean.
I have one coming in next week but did the inspection today.
What I've decided to do is film it on the outside with the customer's permission and may be replace it every 12 months or whenever at client's expense.
Gets over the access problem and my old client is more than happy with that.
Devil
TintsOvOz
krazy.gif It is possible, but a tad tricky, bring the front seats as far forward as poss, you should be able to put 1 foot in between the back of the front seat , cause the glass is small 1 hand or fingers is fine,(very still air current requiered) cruoch down to get visual and then do the work with ya hed on the outside, have a try as the film usage is quite minumal.......... thumb.gif
Ta digger..
Mdog
That backglass ain`t nuttin` mang. Alittle hard to get your hands back there and squeege it out is all.
Well did it this avo and a piece of cake especially since the owner pulled all the door trims for me.
The back window I did by doing a tiny heat shrink and then very simply reversed rolled it onto the glass.
You must be skinny TintsOvOz if you could get a leg and body behind that front seat. You'd be good with a girlfriend mate in there. Flaugh.gif
I just installed it with the seat in the normal position and reached over it. beer.gif
With the trims off it was very easy and the door tripped locked to make the glass come up a centimeter.
Slight fingering on the bottom edge but no need for heat shrinking.
Trims took the bod about 3 minutes to get off.
Dev
zolar
45 min clean install
reversed the teeny BG
held the door switch with my foot to heat the bottom
tintgod
QUOTE (zolar @ Feb 15 2006, 07:46 PM)
[*]372344[/*]
hey Z..all you have to do it unscrew the screw that holds the switch in and the window will stay up thumb.gif
zolar
It only tok a second
besides I like looking like a freak of nature
tintgod
QUOTE (zolar @ Feb 15 2006, 09:42 PM)
[*]372436[/*]
zolar
QUOTE (tintgod @ Feb 15 2006, 09:45 PM)
[*]372436[/*]
[*]372441[/*]
I have pulled a buttload of pinswitches in the alarm biz
Contact: tintdude[a]gmail.com
