2000 Mitsubishi Mirage
Full Version: 2000 Mitsubishi Mirage
if you are just starting out tinting the easiest way to do those is to lay the film on the outside of the glass..trim the straight edge first..slide the film over about a 1/4 inch..then...trim the curved side of the window..keeping the knife blade flush with the rubber seal..but not cutting it...then..slide the film up about a 1/4 -1/8 of an inch..then trim the bottom of the film off.
before applying the film ..you have to trim the inside rubber..about a 1/8 or so of the rubber..clean window good and then install.. good luck..
