tintdude.com logo
Cutting templates - what works
naughtydog
When I am trying to cut film from templates I struggle, what works best to put on the rear of your glasss wall to make template cutting more defined.
Should I just tint the rear in 5% film - would this make it eaier to follow the outline of the template??
Naughty
willie
I may not be reading the question correctly -but are you having trouble seeing the liner you are using for a pattern?
naughtydog
Sorry, I thought it sounded a bit messed up when I re-read it.
Yes, I am struggling to see the liner
Naughty
willie
ok then - I had trouble too when I tried to use the liner like you are on the wall.
I now have a flat table I use and have 2 8' flourescent light below the glass.
It makes the liner well defined and it actually made it easier on me to cut and keep my hand steady.
Try this is inexpensive and good luck.
naughtydog
thanks...any more from anyone else
Naughty
blade
all my glass i cut on have Silver 20 on them.
naughtydog
I will get some silver then - thanks
willie
(blade @ Oct 31 2005, 06:14 PM)
[*]332704[/*]
hmm I hadnt thought of that
even your peeling glass?
would mirrors work the same?
zolar
I use a mirror dunno.gif works o.k. for me
1PEECBARETTA
i don't use templates.
willie
(1PEECBARETTA @ Nov 1 2005, 03:24 PM)
[*]333041[/*]
tintinater
the first guy I worked for 16 years ago used templates, had 'em all organized in old tint tubes. Had 'em catalogued and stuff, but you still had to cut the top edge, so why not just cut the whole window while your there?? It's a time thing to me. Patterns seem like a hassle.
blade
quarter glass windows....vent windows.....use a scrap piece of liner to cut a template. then you don't have to fock with a light to see through the film to the black borders or edges. plus you can double the film up on your peeler and cut both quarters or vents at the same time. that's about the only time i use templates. i never use templates for rollups. templates are nice for vinyling the matrix on bg's too.
TintWizard
(blade @ Nov 1 2005, 07:31 PM)
[*]333173[/*]
willie
(TintWizard @ Nov 1 2005, 07:42 PM)
[*]333173[/*]
[*]333175[/*]
never door glasses here - I do have a few for pickup back glasses but the rest are the same, vent quarters etc
tigerstripe
metint
(tigerstripe @ Nov 6 2005, 04:52 PM)
[*]334719[/*]
That depends on who's cutting the pattern, what method on scanning and who's doing the digital file (clean up).
tigerstripe
(metint @ Nov 9 2005, 05:03 PM)
[*]334719[/*]
[*]335521[/*]
dont forget making sure the guy running the plotter knows how to set it up. otherwise edges are not the shizzle orngbiggrin.gif
metint
(tigerstripe @ Nov 9 2005, 07:22 PM)
[*]335528[/*]
Saw one that was shipped back because owner said it wasn't cutting right... it had so much crud, including what appeared to be red candy goo that must have drooled from someone's mouth, how could the machine ever have cut decently. hys.gif wall.gif
tigerstripe
(metint @ Nov 10 2005, 06:05 AM)
[*]335528[/*]
[*]335669[/*]
I love my plotter and use it almost daily, but its still in the growing up stages.
Contact: tintdude[a]gmail.com
