tintdude.com logo
'01-'02 Lincoln Town Car
busaj
Newbie here looking for some suggestions from those far more in the know that I.
I'm planning on picking up an '01 or '02 Lincoln Town Car. I'm looking to probably set it up with a remote starter, and some sort of sound system upgrade. I need something that's got some bump to it, but I don't need anything crazy, I am afterall on a budget.
What would be a good setup, and what would be a good price to budget for.
P.S. - I'm not object to doing a little dirty work, but I don't have the skills to really dig in and do the job right.
ShowStye05
Hey whats going on? My suggestion for a car that big would be to power the interior speakers maybe about 90 watts per speaker... for something to kick if u want something clean and that will hit hard go with 1 MTX 9500 12" in a sledgehammer box. "Dont buy it without that box and never take it out of that box" just my advise... power it with 1 MTX 801D amp and you will be set to go. These items may be a little costly but if u give me a price u are looking to spend i could definetly design something thats cheaper or even more extravagant... this is toned down and mellow for my tast... let me know what u thing and good luck!
busaj
Hey ShowStyle, thanks for the response. I'm not looking to spend a whole lot, like I said, just looking for something that's got a bit more hit than stock. The setup that you're talking about sounds just like what I had in mind. The two questions that I have about your reco. Would that setup be powering the stock speakers? and How much would that cost to put together?
As I mentioned in my last post, I'm willing to do some work if it's not too intensive, I just don't have much experience when it comes to audio setup. Any advice or insight you can offer is appreciated! Thanks again!
ShowStye05
This setup includes powering the interior speakers... The sub= 750, the amp= 525, and the interior amp runs about 300, if thats to much keep 2 things in mind... this is VERY high quality and a very punchy sub for a 12, but also keep in mind i can design something else with 2 10" subs that would be cheaper.. let me know what u think... good lucK!
busaj
When I get a little closer to putting this thing together, I'll definately keep these ideas in mind! I've actually got a couple of project bikes going right now, so I'll have to see where I stand with budget, but this sounds like the type of setup I'm looking for.
ShowStye05
Your Welcome for the help and idk where you live but i install car stereo's relatively cheap compared to the competition, im in NY so if you are intereseted let me know when you are ready...
SIR TINTSALOT
as for remote starters, prestige is usually reliable and you can usually get a full featured remote start alarm for about 300 installed, if you choose to get the pager with it you probaly looking @ about 375-400 range.
I prefer not to get the pager because after about 2-3 months of putting it in you pocket it tends to look pretty beat up
zolar
I agree on the pager issue, plus they eat batteries
the audio however.......
the town car has an amplified jbl/ford system in it
if it has a small square amp plug on the back of the head (grey cable)
all you need is an upgraded head unit and a sub/amp combo
the new head unit when connected to the factory amp is WAY loud
if this aint enough "words in your mruzik" sweat.gif you can add a pair of tweets up front
if you do this ........the adapter for the ford premium sound
does not have a connection to the cable's shield,
so if you have ignition noise, you can connect a ground wire
to the braided shield of the grey amp cable. (trick metra dosen't even know)
as to amp/sub a single 12 or dual 10s on 350-800 watts is enough to feel
but a combination of 8's or 15's would work well depending on your music tastes
I am not into brand bashin' but the MTX line has given me plenty of headaches
I even called mike at the tech dept in MTX, to tell them how to fix the remote circuit
that caused the amps to draw current through the remote lead, if hooked to ignition
(the 800D) predecessor to the 801 that dude ^ reccomended. I have done this shizz over 20 years
that line will never be on my shelf again.
they have a crappy line, you will blow that shiat faster than a $20 in da' hood on friday
there are plenty of options out there
I would take it to a shop with certified installers
and years of experience, or you will get a hacked up job
busaj
You're all some good people!! I truly appreciate all the help. I'll definately have to be looking into the Prestige line of remote starters, and see who installs them here in the Central NY / Syracuse area. If there is anyone on here that does this sort of work in my area, let me know, I'd much rather send my business to a board member.
Zolar, if you don't mind me asking, where are you located? If you want, shoot me a PM. The options you listed seem like they'd work pretty well for me, so when I finish up my current projects this will be next on the list.
Thanks again everyone, your suggestions and insight are always appreciated here! orngbiggrin.gif
zolar
you could call audiovox, the guys that make prestige
busaj
Zolar, I might actually be down by you sometime around New Years. I'm headed to Atlanta then down to Miami for a bit. Anyhow, I'll definately give Audiovox a call and see who they can refer me to.
I know I'm the man of a million questions here, but I've got another for you. As far as components for the setup you recommended, I know you don't like MTX, who else would you recommend? I listen to all sorts of different music, everything from hip hop, to techno, to a decent amount of heavy metal, so I'd want something that's got some clear sound, and good but not ridiculous bass. Any suggestions, as usual, are appreciated! beer.gif
zolar
I am fond of several brands..........
I tint for a large RF dealer, they have a HQ line in every price point
The best sounding system I ever did was MB quart mids/highs, and old school orion subs and power
with some studio equipment converted to 12V, but that would be pricey
I think it more important to find a dealer that you are confident in
that has experience with your vehicle, and a top-shelf audio/security line
and installers with years of experience.
you could make the car sound great with a "B" line
and a less experienced installer
....but it could bite you in the arse later
MECP certification is a plus, ask if they have certified installers, and a portfolio.
I would trust a long standing independent store over the lines at Wallyword, or the Big Box guys
you might spend a few more dollars, but you will remember quality, craftsmanship, and service
.............long after you have forgot about the price.
I dont do much 12V anymore, but I will gladly help you any way I can
ShowStye05
<snip>
zolar
TintDude
Easy big fellas. This kind of thread really discourages new participants.
busaj
I'm not following the snips, I assume I missed something that was later edited by tintdude. icon_confused.gif
All the same, I wanted to thank you guys for the input, your comments and opinions are appreciated, especially from someone like me who's knows next to nothing about these sorts of things.
Great website, and thanks tintdude for trying to encourage new members to join and post! thumb.gif
Contact: tintdude[a]gmail.com
