tintdude.com logo
Subaru Outback Wagon
Full Version: Subaru Outback Wagon
tintinater
I thought I'd done one of these before, but I don't remember the rear quarters being such a pain.
First of all the seat belt thingy comes down the whole window, about 2 inches from the glass, and doesn't flex much at all.
Second, the damn thing had an aweful lot of fingers, it was like those old Probes, where you heat up one finger and it turns into two bigger ones. I'm a stretcher, my first instinct isn't to shrink, so I ended up redoing them, shrinking them this time.
Anyway, my question is, has anyone taken this rear panel off to remove the seat belt thingy, how much of a pain in the ass is it? I was able to tint it , I squeegeed, flushed the hell out of it, peeled about three quarters of it, slide it behind the seat belt thingy, positioned it, peeled the rest, done. But it could have been cleaner.
TintWizard
It's all in where you hold the peice for loading it in..hard to explain in type..the key is lots of slip so you can slide it along the glass to its destination. I place it as close to the belt as I can keeping the rest of it away from the glass , then pick up the very top edge corner again from the other side of the belt and slide it into place removing nothing for a clean install (after heatshrinking piece..forgot that part ) Hope this made SOME sense Flaugh.gif
tintinater
I know, that's what did, but it would be soooo much easier, I figured you might have tried, I'll probably try on the next one....
tint-it
Don't worry bout the seatbelt bracket. Just go slow and lay the film... as for heat shrinking it, keep the factory edge on the straight edge of the rear quarter... squeegee the curved edges and shrink the factory edge. it's easy Potsy - "i'm a stretcher" - I love it
VR6freak
I just did one today, and did a mini reverse roll,lots of slip then unroled the front facing section and slid it into place...cake. thumb.gif
Contact: tintdude[a]gmail.com
