what shade should I use
SIR TINTSALOT
Dec 31 2005, 09:33 AM
I just lined up a few good jobs for next week and I am trying to determine what shade I should use. I got 3 Burger King restaurants to do, one next week and two the week after. They sent me to see one that has colored glass and told me they want the 3 with clear glass to match the one with colored glass. To me it looks like 20% with not much reflectiveness to it. I usually use suntek or johnsons for this, but the suntek commercial line is way too reflective. Johnsons gots a film called DN20 that seems to match pretty good, but it is hard to tell from a small swatch if it is going to be too refective or not. Things sometimes look way different once applied to big windows. The shade I am looking for is real common on stores and schools that have factory tinted glass. So those of you that know this info please let me know asap cause I need to order the film on Monday. By the way this is a good way to start off the new year, I got 3 burger kings, and one car dealer to do in the first two weeks. Hopefully that is a sign that business is going to be great this year.
metint
Dec 31 2005, 09:39 AM
35%... 20% is too dark... is it grey, bronze, green, or blue tinted glass? Dual pane?
SIR TINTSALOT
Dec 31 2005, 09:43 AM
single pane, it has a charcoal smoked look to it. From all the swatches it looks darker than the 35, and when I should some larger samples to the guy in charge he said it was definitely darker than 35. I'd h@te to put the wrong shade and have him unhappy. Plus the outcome if this job is going to be the weighing factor on whether or not he has me do the other two.
willie
Dec 31 2005, 09:46 AM
congrats on starting the new year with a bang however tell them your not burger king and they will get it your way just kiddin - good luck with them
SIR TINTSALOT
Dec 31 2005, 09:48 AM
thanks willie
I'll check back this afternoon, I got 2 cars I got to go do. any good advice is welcome.
Where's Tint when you need him?
metint
Dec 31 2005, 09:58 AM
Have a 2 pc light meter to measure the glass VLT?
It's possible you are facing that dark of a glass...
Have you held up different samples next to this pane?
Most the time a sample will appear darker... this is because of all the light streaming by and around the sample. If you put up 35% sample and it matches, it is more than likely a 20% glass and so on.
Light meter will give you a definitive answer without a sample shuffle.
blade
Dec 31 2005, 10:34 AM
it's always a pain in the azz to try and match up with tinted glass.
TintWizard
Dec 31 2005, 10:37 AM
(SIR TINTSALOT @ Dec 31 2005, 11:48 AM) any good advice is welcome. Where's Tint when you need him? [*]355821[/*] What's THESE to sentences doing together in the same post
willie
Dec 31 2005, 02:29 PM
[quote=TintWizard,Dec 31 2005, 12:37 PM] [quote=SIR TINTSALOT,Dec 31 2005, 11:48 AM] any good advice is welcome. Where's Tint when you need him? [*]355821[/*] [/quote] What's THESE to sentences doing together in the same post ] best post of the year TW and you saved it for the last day
TINT
Dec 31 2005, 04:12 PM
(TintWizard @ Dec 31 2005, 09:37 AM) (SIR TINTSALOT @ Dec 31 2005, 11:48 AM) any good advice is welcome. Where's Tint when you need him? [*]355821[/*] What's THESE to sentences doing together in the same post  [*]355842[/*] what am i good for? STA- best bet would be take someone with you and have him serve you a second opinion, or ask the restaurant manager, iv'e had many same circumstances where i've had to match film, but as you know, as we all know, if its film on those windows now, its always going to be a slight bit of a difference, in color, or in shade percentage, i woudnt guarantee an exact match, unless they know the brand that those windows were tinteed with and what percentage exactly. and even then that film has been exposed, because of that reason, even if you get the exactly film, it still wont match because your applying new film. capiche?
SIR TINTSALOT
Dec 31 2005, 09:35 PM
I'm trying to find film to match a colored glass, not a film. It is a real common color that I see on 75% of shopping centers and business windows. It is a smoked look, almost identical to 20%hp suntek, but like metint said it might be 35%. I wish I had a light meter!!!! I'm thinking of putting 35%. I'll go by monday morning and double check before ordering.
TINT
Dec 31 2005, 09:36 PM
35%
tintgod
Dec 31 2005, 09:37 PM
go get a light meter...and make sure dude
tintgod
Dec 31 2005, 09:39 PM
maybe you can ask them who put the windows in and call them and ask them what type and shade of window they are..
TintDude
Dec 31 2005, 09:43 PM
tintgod
Dec 31 2005, 09:44 PM
wow..that is the best advice i have givin on here in a long time..
SIR TINTSALOT
Dec 31 2005, 10:11 PM
thanx guys, see ya next year I got a limo outside picking me and my guest up....TIME TO GET DRUNKKKKKKK. HAPPY NEW YEAR
willie
Jan 1 2006, 05:15 AM
(SIR TINTSALOT @ Jan 1 2006, 12:11 AM) thanx guys, see ya next year I got a limo outside picking me and my guest up....TIME TO GET DRUNKKKKKKK. HAPPY NEW YEAR [*]356251[/*] 12:11 am already next year
SIR TINTSALOT
Jan 1 2006, 07:01 PM
That was 9:11 where I'm at. Had way too much fun last night(I mean last year)
VO|TRON
Jan 1 2006, 09:27 PM
you could always put a mock up piece of 35 and 20 to see which one matches the best.
metint
Jan 2 2006, 06:50 AM
(VO|TRON @ Jan 1 2006, 11:27 PM) you could always put a mock up piece of 35 and 20 to see which one matches the best. [*]356574[/*] Good idea... not many tinters see the value in using film in this way. I once did a job where they wanted to see Vista 38 and Vista 28 side by side... did it in a den with four panel window setting looking across mangroves to the Gulf. The job was awarded they just couldn't decide... meanwhile distributor stockpiled V-28 in anticipation... they chose V-38 and it had to be drop shipped from Martinsville because... well it's been said. Went from that 550 sq ft condo to doing the whole building. Example used, one was removed and replaced, but not wasted.
Contact: tintdude[a]gmail.com
