'61 Chevy Impala Bubbletop
Full Version: '61 Chevy Impala Bubbletop
Guys got a backglass out of that car wants it tinted. What do you guys think?
Yeah thats it same picture I found on Google. The only picture. What do you guys think about it Are they hard to do or easy? Doesn't look like it has defroster lines so a seam wouldn't look to good. I don't know.
it looks like it would be pretty difficult, especially if you have to use a difficult to shrink film
the film lays down pretty much perfect everywhere except the top right and left hand corners. the only one i've ever done, i just forced the fingers to those corners and shrunk it down. if you have the glass out of the car, you got an easy job.
Killer B I do tinting for a little shop thats kinda like those dudes on the discovery channel there called Greening Auto and just like on the discovery the guy that owns it is named Jesse James It's him and his dad real funny and they rebulid some super duper slick ass rides man I will have to take some pics and show you all its really amazing the things they do to these old cars. Anyway they got the bg out while there rebuilding it thanks for the info tintshop sounds like I got it made.
Double
Calling all tinters. Any of you that have done this bubbletop crapin backglass in one piece whats the best method to use to shrink the b***h out?
having trouble eh?
i just noticed from your pic that it looks like laminated glass, id be carefull not to get it too hot.
I did it dry for the 1st part and got what I could to lay down then I lifted it up and wet under it for a wet shrink. I worked with it for a while wetting it and moving it up to shrink then moving it back down on the glass to get the film shrunk all the way to the edge, but when it seemed that the more I shrink the worse it got. I got the top to go down all the way and two vertical sides looked like the would stick down when I install it with a little heat and pressing it down on the glass like the beretta. but the bottom is where the problem occurs. Any help will be considered, but I think that if I really take my time I can do it I'm just use to shrinking the honda accords that take like 5 minutes to shrink and be done I'm not use to having to take my time. another thing if I am able to get it in one piece what do you think a fair price for something like this would be. Thanks
hmmm, i might try the wet pull method on that one. As far as price...2 bills.
will do Td but I have never used the dry shrink or baby powder or any of those on a glass that is this difficult and the kind that has no frit to work on. I've done old ass cars where the glass goes all the way into the rubber but they where easy enough to do wet. and when you do a glass the goes to the rubber I have always put the film on wet like normal with the film hanging off the edges then I move the film up or down so the film is like 1/4 of an inch off the rubber so I can shrink it completely. but with the dry shrink I guess it would be about the same. I don't know. Preciate it though
TTS where you at on this one man. You said it should be an easy shrink. I guess your more skilled with the heat gun then I my friend. Give a brother a little advise here. and take a look at those pics to make sure we're talkin about the same backglass and all.
I do a lot of classics for people in my area. Most people know of our shop to bring the hard and classic cars. I wet mold everything, except beetles. For this I would make the typical H pattern trying to split the stress evenly from top to bottom. Make your first cuts as close to the edge as possible, leaving yourself "burn" room, if needed. Then just take your time molding without putting too much heat on the problem areas. Go back and forth pushing as much stress as possible to the center where it is less curved. If you think its getting too hot, go to another side, then come back to that prob area and throw a little water back on it and complete the mold. Also.... because you have it on a stand grab a stool and sit there molding it. Makes it alot more comfortable.
When youre prepping it go over the edges with a flat blade and then steel wool or scrub pad. CLEAN THE shiot OUT OF IT!!! Then take a hose to it, if possible. (that will cut down on any contamination) From there install should be pretty straight forward. Hope that helps!
Thank You FBJ I think those are some wonderful ideas and I will certainly use the old stool sit and shrink trick.
sorry cloud, i just now saw this. i used baby powder, and i didn't have any problems. i only had to shrink the top corners, the rest laid down with out shrinking. if i had to shrink the bottom, i don't remember it. but i almost know i didn't have to shrink anything but the top corners. i had the glass out also, and it wasn't that hard. it reminded me of the john deere tractor doors. basically the same shape, and only need to be pulled to the corners and shrunk. it's hard to tell you with out showing you. but it's not as bad as it looks. my dad restored the car i did it on. i'll see if he has any pics of it. i don't know that it would help, but i'll check anyway.
Thanks TTS it might help if you can come up with those pics. I will have plenty of time to try diff shrink methods so I will try only shrinking the corners. Thanks again.
i just called him and he said he didn't know if he still had them or not. i'll get them if he does.
This is kinda big for me I really want to get this done for this guy cause he is a good customer and I want to keep it that way. Thank you to everyone input.
hey cloud, you should try the baby powder shrink on that one....it's the way i'd do it, and it looks fairly straightforward if you've powder shrunk before
QUOTE (TintDude @ Aug 29 2003, 06:11 PM) i just noticed from your pic that it looks like laminated glass, id be carefull not to get it too hot.
I've got one coming next week. The shrink looks easy, im guessing the rubber surround will be nasty. Is everyone cutting short & using vinyl tape on exterior or leaving daylight or hiding the edge ? Tips are appreciated, i've never had the pleasure of doing one.
Sides are cake the rear top corners are a MF but can be done. took me more than one try. If you can pull the rear glass its ten times easier to fit and it looks sooo much cleaner. I tried once in the car and then had the glass pulled.
![]() ![]() Hardest back window I've ever done...If the glass is out of the vehicle though it shouldn't be bad.It was difficult because it's so bowed you can't really cut it right on the exterior. I had to shrink it outside, cut it, shrink it inside as best as possible, then for safe measures I made as many fingers as possible and shrunk again outside...PITA
