HELP WITH COREL DRAW
Full Version: HELP WITH COREL DRAW
WHEN I USE COREL TO CUT OUT A GRAPHIC , SOME AREAS OF THE CUT R VERY JAGGED. I HAVE ALREADY SMOOTHED UP LINES BY DELETING NODES AND ITS STILL JAGGED. I CAN ROTATE OBJECT AND IT JUST MOVES TO ANOTHER PART. I AM USING VINYL CUT AT SHOP AND AM JUST PLAYING AROUND WITH THE COREL DRAW. PS AM USING ROLAND CUTTER. HELP.... THANKS
are you trying to cut with the corel program, or do you have a plug in like sign tools,
sign tools is designed to cut drawings in corel, they are on the web.
I try not to use corel that much anymore, there is alot of programs that are so much easier.
(SIR TINTSALOT @ Feb 21 2006, 01:18 AM) I try not to use corel that much anymore, there is alot of programs that are so much easier. [*]374074[/*] I finally got flexi...... that will work (zolar @ Feb 21 2006, 05:01 AM) (SIR TINTSALOT @ Feb 21 2006, 01:18 AM) I try not to use corel that much anymore, there is alot of programs that are so much easier. [*]374074[/*] I finally got flexi...... that will work [*]374115[/*] flexi rules yo zo what vergin are you using?
