I have not done one in
I have one Sat. and my fallback guy (MR P) will be out of town :(
01 Buick Century
Full Version: 01 Buick Century
Does anyone know if the 01 has the same BG as the 03. The one with the reverse curve
I have not done one in I have one Sat. and my fallback guy (MR P) will be out of town :( ![]() looks easy enough
it is not bad
Damn, you guys are A LOT of help
Do you have to pull the rear deck to remove the brake light
it has been awhile since i have done one. if there is one i believe you can get behind it....
i can't remember for certian
but I believe you have to pull the deck or cram some liner in there...and get out the bulldozer
ITS CAKE TO GET BEHIND THE LIGHT YOU SHOULD HAVE NO PROBS
OK Now thats better...
Help a sista out QUOTE (imfear44 @ May 10 2006, 03:23 PM) ITS CAKE TO GET BEHIND THE LIGHT YOU SHOULD HAVE NO PROBS [*]397216[/*] Why are you yelling
sorry key board s*cks,
Oh and this does have the reverse curve at the bottom and you have to remove the entire fckin rear deck to remove the third brake light!
Just an FYI
did one of these the other day..........entire car pissed me off. nothing wanted to go right or lay down right..........finnally got it done. didn't have anything else going the rest of the day so i just took off. i guess every tinter has a bad day once in a while.
