Remote Start Not Working on Ford Explorer
WeeWanker
Jun 3 2006, 11:39 AM
My wife has a 2002 Ford Explorer with the Ford security/remote start that has stopped working. It has done this once before, but it was just a 5amp fuse that time. What happens is that when you press the start button, the vechicle locks the doors, soleniods click, the dash lights go on as if it will start, but nothing. It then repeats the cycle 3 more times with the 5 second delay then stops trying as normal. It starts fine with the key. I've checked all the fuses by the under-dash modules, (2 x 25amp, 2 x 15amp, 1 x5amp), and all are fine. The rest of the functions work fine. IE: when it is running with the key, if you press the start button again, you can take the key out, lock and unlock the doors. It just won't engage the starter with the remote. With black leather interior, and the hot summer coming, my life would be easier if I can get this working so she can have a cool interior.... Does anyone have any thoughts as what to check next? Thanks in advance, WW
Guest
Jun 3 2006, 02:28 PM
Check your hood pin. Most place will install one so the vehicle will not start if the alarm see's the hood open. Usually those things will get snapped off, or rusty and what not.
Just open the hood.. find the plunger pin switch... press it down with your finger so you know it is down.. and try to start the car while holding it down..... (or just unplug it and try to start the car)
typically the only 2 things on a remote start that will keep it from cranking is
1) it see's the hood open 2) it see's the brake pedal being depressed 3) You have a bad connection (t-tap) where the alarms taps into the crank wire
that's it.... nothing else.. motor easy..
Guest
Jun 3 2006, 02:29 PM
ok.. maybe 3 things... Haha!
zolar
Jun 3 2006, 03:42 PM
stick the key in the ignition without switching it on if it will start remotely ..... ............you have a bad transponder/immobilizer bypass module
Guest
Jun 3 2006, 04:33 PM
I don't think a bad transponder module would keep the rig from turning over... but it would keep it from firing.... Good test.. worth a shot..
WeeWanker
Jun 3 2006, 08:46 PM
Thanks for the suggestions. I'll give the hoodpin a shot in the morning.
I've tried with the key in the ignition but off, and all that happens is the the unit beeps twice and will not attempt anything, so I don't think it's a transponder issue.
I'll advise what happens.
Thanks, WW
WeeWanker
Jun 5 2006, 06:59 AM
Thanks to the suggestions. It's working again  I checked the hood pin with no luck. Then I rececked everything under the dash. What a mess for a Ford installed product. There must have been a loose connection somewhere, because when I was done, it was working fine. WW
Guest
Jun 5 2006, 07:15 AM
WeeWanker
Oct 31 2007, 08:21 PM
 It's happening again. I pulled out the entire system, verified evey fuse and relay. I did NOT change/bypass the hood sensor at the time, (I didn't think of it until after.) Once I receonnected all, worked for ~ 6 remote starts in a row. All remote funcions work, door locks, remove key and keep running, etc. Start funtion tries four times then stops. I haven't noticed and difference on either console theft light or alarm system led flashing differently. Someone I talked to suggested checking the steering ring sensor??? Also, just a side note, the system has a 3wire, (4 pin jack) by the firewall that seems to sometimes start if I plug/unplug it as I am trying remote start. Anyone have any thoughts????? Thanks, WW
sunslayer
Mar 3 2008, 09:21 AM
possibly a bad connection in that plug?
cartek
Mar 5 2008, 01:14 PM
QUOTE (Guest @ Jun 3 2006, 04:28 PM) [*]402626[/*] Check your hood pin. Most place will install one so the vehicle will not start if the alarm see's the hood open. Usually those things will get snapped off, or rusty and what not.
that's it.... nothing else.. motor easy.. i have never seen a remote start system that will still allow it to go through all the steps to remote start(minus cranking) from the hood and brake. if it were one of the first two things it would not even attempt to start. no light flashes, no ignition, etc.
QUOTE (cartek @ Mar 5 2008, 12:14 PM) [*]600428[/*] QUOTE (Guest @ Jun 3 2006, 04:28 PM) [*]402626[/*] Check your hood pin. Most place will install one so the vehicle will not start if the alarm see's the hood open. Usually those things will get snapped off, or rusty and what not.
that's it.... nothing else.. motor easy.. i have never seen a remote start system that will still allow it to go through all the steps to remote start(minus cranking) from the hood and brake. if it were one of the first two things it would not even attempt to start. no light flashes, no ignition, etc.  Thats what I was thinking it sounds to me like you have a DEI remote start. If so check the purple starter wire from the remote start see if its connected good, maybe its a bad t-tap. When your alarm beep twice, which means there was an active shutdown. Either your hood was open or foot on the brake or if installed your netural safety switch was off.
QUOTE (WeeWanker @ Jun 5 2006, 05:59 AM) [*]403013[/*] Thanks to the suggestions. It's working again  I checked the hood pin with no luck. Then I rececked everything under the dash. What a mess for a Ford installed product. There must have been a loose connection somewhere, because when I was done, it was working fine. WW  You said it was a ford installed product, what alarm R/S was installed? Dealers usually do audiovox.
FREDSTINTING
Sep 29 2009, 03:19 PM
sound like factory by pass module is going bad and not sending correct signal to the starter some times the wires that you coil around the ignition switch is not sensing the key that is in the by pass module and will try and try but will not start .
to check this by putting key in the ignition and then shut the doors and stand out side and try to start with your remote should start with key . if it does replace the bypass module if it doesnt something else is wrong in the wiring
Contact: tintdude[a]gmail.com
