Two pieces of glass... silicone used to join the two. And then they again used silicone on the sides of the glass to secure it in the window frame.
What is the ideal way to tint that? I can't use my bondo since there isn't really an edge...
RoAcH
How to get a clean edge w/o any "edge"
Full Version: How to get a clean edge w/o any "edge"
What is the ideal way to tint that? I can't use my bondo since there isn't really an edge... RoAcH
You can take a straight edge ruler and olfa blade to make the silicone , dry scrape the excess silicone off leaving and even ,yet still functional silicone in place, then use the factory edges of your film and butt it up against the silicone..this would be one way
Blackout tape!
A lot of that stuff is beveled glass. Cut and scrape excess silicone to the bevel and either use a straight edge or angle your blade off of the bevel and cut free-hand. Make sure you scrape all of the excess silicone, even the haze that is left over after you cut the excess.
We have done some windows just as you described recently. And just as TW said use a metal ruler to trim the side that is not oyur striaght edge. Be careful though! That shiot attracts dirt which will seep under the film on the edges! We just sprayed the film, not the glass!
what vclimer said,
use some acetone and a razor to clean down the the bevel, and fear butt glazed windows no more
Thanks for the tips.... I'll try them out next time.
Man, talk about time consuming. Took me a lot longer then normal windows. RoAcH
glazes my butt just thinking about it
try to get in der before the caulk guy does. Had to scrape a lot of shizz of the edges for this monstrosity even tho there wanst a lot of surace to be covered
![]() and always make sure the caulk is hard before trying to set the film. This job was caulked in the morning, and had to be filmed by 4 pm. Somtimes ya gotta do what ya gotta do.
please tell me you used a plotter for the lines
I could see me trying that shizz with a ruler
Plotter? Whats a Plotter ?
The individual lines were plotter cut, but each of those green lines were hand set. The upper lines are on the outside of the glass, and the lower lines are on the inside. BECAUSE thats the way the Azzchetecht wanted it. No arguing with them. so they had to pay $$$$$$ oh yeah, those lasers work great for lining things up, I would still be there if lowes wasnt blowing them out for 25$
looks good as a mug
I have some butt glaze storefronts to do soon hopefully I will have to charge extra for the caulk gimmick cool tip yodamang (tintyoda @ Jul 20 2006, 08:17 PM) [*]415044[/*] Plotter? Whats a Plotter ? The individual lines were plotter cut, but each of those green lines were hand set. The upper lines are on the outside of the glass, and the lower lines are on the inside. BECAUSE thats the way the Azzchetecht wanted it. No arguing with them. so they had to pay $$$$$$ oh yeah, those lasers work great for lining things up, I would still be there if lowes wasnt blowing them out for 25$ CP makes some Deco Film that looks just like that stuff, no cutting needed except for the width.
correction,,,,
THe white strips are from solyx , No way in helll im hand setting that shizz.
