tintdude.com logo
abbeviation explanation
siky.121
Hi everybody
I just bought a car alarm and I tried to put it into my car. I look in the machint circuit diagram and found out that pluging the contacts is explained with the abbreviations NO, C, NC, No1, C1, Nc1 and there is written layout graph of central control lock and do not know what those abbreviations means.
Thanks for help
zolar
on a relay the contacts are NC [normally closed] if they have continuity at rest
and NO [normally open] if not connected at rest
the relay has 2 contacts on each side [85 and 86] that get +12 and ground to energize the relay
the 3 other terminals are....
30 [common] 87A NC and 87 NO
30 is connected to 87A when the relay is off
30 connects to 87 and dis-connects from 87A when 85 & 86 are energized
there are several types of door lock circuits
and some have high current wires that can get real nasty if not interfaced properly
autotinter
Contact: tintdude[a]gmail.com
