tintdude.com logo
REMOVING CDA/CDF ADHESIVES
clark kent
I HAVE A 100 SQ. FT. TO R/R WITH OLD CDA . ANY IDEAS ON THE BEST WAY TO TAKE THIS ADHESIVE SYSTEM OUT OF THE GLASS ? icon_confused.gif
vclimber
Try dry scraping first, if it's not successful, then try pulling the film and soaking. Are you planning on re-applying film after you strip it?
clark kent
(cclimber @ Sep 23 2006, 08:49 AM) [*]434296[/*]
yes- totally demetalized and this adhesive is really integrated into the glass and i need to pull it out. I've heard about using baking soda , however i have no experience. also does temperature affect this as it does with ps. any help? icon_confused.gif
vclimber
If you are plenning on replacing the old film with a PS film use Cerium Oxide and a polishing brush mounted on a cordless drill. That will remove the remnants of the dry adhesive so you can install the new film.
zolar
vclimber
(zolar @ Sep 23 2006, 01:52 PM) [*]434365[/*]
clark kent
(cclimber @ Sep 23 2006, 01:43 PM) [*]434361[/*]
WOOF , ARE YOU SERIOUS- CERIUM OXIDE,POLISHING BRUSH- LOOK'S INTENSE-ANY RECOMENDED #'S PSQFT FOR REMOVING-MABEY CHEAPER TO GET NEW GLASS. I LIKE THE BRICK IDEA THE MOST. bat.gif
vclimber
(clark kent @ Sep 23 2006, 02:50 PM) [*]434389[/*]
Have you ever tried installing PS film after you've strip CDF adheasive? I am very serious, it can be a nightmare. I figure about an extra 20 minutes per 4x5' pane, it usually takes less though.
Roach
I remember a couple years ago I did a R&R down the shore... the film had bubbled.... it was very old. I'm trying to remember.... I think it just flaked off as I was scraping.
I've done a number of R&R... back when I was working for a Vista dealer, so the new films were always CDF... Never had any problems that I can recall. But I'm not sure what the old film was - PS or CDF.
Did one a few months ago, but the new film was actually Huper.. can't remember what the old film was. It was at an old bank.
clark kent
(Roach @ Sep 23 2006, 06:54 PM) [*]434475[/*]
BUT IF YOU REAPPLY CDF/CDA DO YOU STILL HAVE TO PULL ALL THAT ADHESIVE OUT ? icon_confused.gif
vclimber
(clark kent @ Sep 24 2006, 07:25 AM) [*]434550[/*]
In most cases NO.
TINT
TINT OFF
clark kent
(TINT @ Sep 24 2006, 09:12 AM) [*]434582[/*]
TINT OFF
Contact: tintdude[a]gmail.com
