Alfa Romeo 156 2000 model, anything I should know?? Im a panel puller usually but if need be I will leave the trims on..
Anyone got ant tips??
Full Version: Alfa Romeo 156 2000 model
Alfa Romeo 156 2000 model, anything I should know?? Im a panel puller usually but if need be I will leave the trims on.. Anyone got ant tips??
Hi JJ
We've done a few but I can't remember without seeing the panel. From memory I know some of the screw covers are deep/tricky to get out without marking although I might be mixing it up with the GT anyway they break real easy - so go careful.
Thanks Tintim,
it was just a quote, guy hasnt booked in yet but will go easy and look for hidden screws when he does.
Anytime JJ,
I Remembered that you have to take the parcel shelf out to tint the rear screen, and I think like the 166 the very bottom of the rear screen has some slight overspray or mastic so make sure you give that bottom edge and good wire wool or cut off any excess mastic. Otherwise the tint does not sit down so good or looks to have excessive contamination. Good luck.
Thanks again Tintim
jj
