02 honda accord coupe
Full Version: 02 honda accord coupe
Im having trouble tinting the back window of an 02 honda accord. Im using a dryer sheet and am not having problems doing the bottom half of window but the top corners. Ive tried to leave the film long on top and pull while i shrink it and i keep getting kinked up in the corners. Any suggestions?
that cars really easy to shrink man...i always wet shrink them but if you cant even do it using the dry method dont bother with it wet. why are you still using dryer sheets...are you new to tinting? the only problem i've ever had was having the matrix stick, i dont know if its the curve of the glass because the matrix is only like 2 inches but it just hates to stick. I have since perfected my matrix skills on the coupes but good luck if you cant even get the BG shrunk.
(BLACKOUT SoKal @ Oct 26 2006, 06:22 PM) [*]442979[/*] that cars really easy to shrink man...i always wet shrink them but if you cant even do it using the dry method dont bother with it wet. why are you still using dryer sheets...are you new to tinting? the only problem i've ever had was having the matrix stick, i dont know if its the curve of the glass because the matrix is only like 2 inches but it just hates to stick. I have since perfected my matrix skills on the coupes but good luck if you cant even get the BG shrunk. Says he has 10 years exp.
