tintdude.com logo
Help! 95 Dodge P/U rear window
TIFFY TINT
i have tinted plenty of windows, but i am having the worst time with this window. how do you tint a window all the way up to the rubber without taking it out? each time i do it i have light gaps. its the back window of a 95 dodge ram with a slider.
Texastintchick
I personally trim out a little rubber around the inside. Trim it on the outside to the actual size of the gasket. Then install. dunno.gif works for me!
TIFFY TINT
that wont work as some of it is hard like plastic
willie
QUOTE (TIFFY TINT @ Mar 2 2007, 10:49 PM) [*]485161[/*]
heat the plastic a little and it will trim like the old ford sliders
thats probably in the top 3 worse sliders ever
TINTZEUS
maybe try only letting your blade out 1"click"...and cutting at a different angle..... dunno.gif for a tighter pattern.
or cut from the inside.
exotic window tint
if it already has factory tint on it trim the outside as close as u can then take it inside and trim it in there too thumb.gif good luck
Contact: tintdude[a]gmail.com
