2002 Dodge Sprinter
FilmBlazer
Mar 26 2007, 02:24 PM
Large windows, no overlap available with thick dense rubber seals that are equal thickness and height on both interior and exterior. I need to bid 15% or 20%. Any tips on making this install look good without the overlap?
Whats the best cutting method? What are the best tools for the rounded corners on the windows? The job is sold, and its for a dealer, I just want to make sure it looks good and I make money because these windows are BIG.
Thanks for the help!
FB
FilmBlazer
Mar 26 2007, 06:04 PM
Bueller? Bueller? Anyone? Anyone?
tintman237
Mar 26 2007, 06:07 PM
those are some big azzz windows, I usually cut em on the inside. If you want to and have a very steady hand, cut a little channel in the rubber, like a 1/4 glass and california roll it when you install it. P.S. I'm not Bueller, I'm Beavis
FilmBlazer
Mar 26 2007, 06:37 PM
Ahhhh yes, you're saying to cut into the rubber to create my own overlap? Its some hard ass rubber!
FilmBlazer
Mar 26 2007, 06:38 PM
QUOTE (tintman237 @ Mar 26 2007, 09:07 PM) [*]493673[/*] like a 1/4 glass and california roll it when you install it. Help on the lingo pls
tintman237
Mar 26 2007, 06:49 PM
 translation costs big $$$$ 1/4 window = small triangle window on back doors of cars if they are rubber set do you trim a little bit of it out? california roll = reverse roll, do you do any flatglass?
FilmBlazer
Mar 26 2007, 06:58 PM
QUOTE (tintman237 @ Mar 26 2007, 09:49 PM) [*]493685[/*]  translation costs big $$$$ 1/4 window = small triangle window on back doors of cars if they are rubber set do you trim a little bit of it out? california roll = reverse roll, do you do any flatglass?  I typically do not trim the 1/4 windows although I may start after your advice. To be honest I do very few cars but its difficult to turn the money away so I find myself doing more and more . Gotcha on the California roll, but I call it the Meeeecheeegan roll up in this piece.
tintman237
Mar 26 2007, 07:03 PM
FilmBlazer
Mar 26 2007, 07:22 PM
Thanks TM
FilmBlazer
Mar 29 2007, 07:57 AM
Yeah, well I have the van here, but I can't get it in my garage lol. Too GD tall! I guess i will be cutting on the inside
wilcax
May 24 2007, 07:13 PM
why not just pull the windows out, no gaps and alot easier/cleaner install  we did this one today, pulled the 4 large windows and took the little locking mechanism off the sliding windows. came out really nice with atr 05
FilmBlazer
May 24 2007, 07:44 PM
Looks good! I trimmed the gasket slightly and it came out just fine. I was using 20% though, pulling the windows would be a good idea for 5% but it sounds like alot of work!
Contact: tintdude[a]gmail.com
