tintdude.com logo
Dotmatrix
Full Version: Dotmatrix
Newbie
Hi, can someone advice how to deal with the rear windows on a BMW coupe?
They are frameless and hinged, and have dot matrix around all edges, just worried that if I cover whole glass, that it won't stick around edges, or might peel later down the line when opening/closing the glass.
Yep, I'm new to this...
1PEECBARETTA
clean the dot area well with a white scrub pad with rubbing alcohol, and tint over the dots by a cm or 2, it will be just fine. welcome to the board !!!!
Newbie
Thanks!
Next dumb questions,
Where to buy rubbing alcohol?
Where to buy alcohol based foam window cleaner? I've heard that ammonia base will eventually eat film glue.
Cheers again.
1PEECBARETTA
rubbing alcohol is sold everywhere here in the states. rubbing alcohol is also isopropyl alcohol
TINTZEUS
Newbie
should I remove the window?
Looks tight.
naughtydog
Just tint past the dots - you dont have to remove them.
Have you actually looked at the window?
Contact: tintdude[a]gmail.com
