NIGHT VISION 25
Full Version: NIGHT VISION 25
Anyone have information on this film
Thank you brother, but I was looking for more than 3M's brochure specs. Anyone else want to take a wack at it?
OK, so what exactly do you want to know
Im looking specifically for solar absorbtion. Need to know if this film is safe for dualpane.
Indpendent lab study specs would be ideal. 3m says it is but in the same breath say can not guarantee
Also does anyone know of an equivalent
NOTHING is guaranteed in life.
I've laid over 800 sq/ft of it or so on low-e windows. Arches too. V shadows, etc. No breakage.
All information is much apprieciated. Thank you.
(tintcousa @ May 24 2007, 11:56 AM) [*]509322[/*] Also does anyone know of an equivalent 3M NV25....usually safe. Hanita's Optitune 22/30.....usually safe. Llumar DR25....sometimes safe. Suntek SymphonyDS 25.....sometimes safe. Vista V28.....usually safe Global Dual Reflective.....sometimes safe. SILVER 20!!!!.....ALMOST always safe. (tintcousa @ May 24 2007, 12:56 PM) [*]509322[/*] Also does anyone know of an equivalent Try Madico Starlite series (SL) or Acuity Outlook Series...both on all glass all the time... (Bulldog @ May 24 2007, 06:43 PM) [*]509405[/*] Try Madico Starlite series (SL) or Acuity Outlook Series...both on all glass all the time... SL-280-CSR will work GUARANTEED and has the same TSER (Bulldog @ May 24 2007, 08:43 PM) [*]509405[/*] Try Madico Starlite series (SL) or Acuity Outlook Series...both on all glass all the time... Really? Even at 5000 feet with ambient temps of 110 on an east facing window with a V-shadow in a concrete frame with old hardened glazing? (darkdan @ May 24 2007, 07:07 PM) [*]509417[/*] Really? Even at 5000 feet with ambient temps of 110 on an east facing window with a V-shadow in a concrete frame with old hardened glazing? (darkdan @ May 24 2007, 10:07 PM) [*]509417[/*] Really? Even at 5000 feet with ambient temps of 110 on an east facing window with a V-shadow in a concrete frame with old hardened glazing? Dood ask who will warranty it, not will it work. Some self judgement on elevation and shading should be used as well as experience. Those manuf. will cover, but still doesn't make up for the pain in the arse IF it has probs... (darkdan @ May 24 2007, 12:08 PM) [*]509345[/*] 3M NV25....usually safe. Hanita's Optitune 22/30.....usually safe. Llumar DR25....sometimes safe. Suntek SymphonyDS 25.....sometimes safe. Vista V28.....usually safe Global Dual Reflective.....sometimes safe. SILVER 20!!!!.....ALMOST always safe. DD luvs his silva, don't he?
The V28 and several others previously mentioned are available in 72 inch widths, NV25 is not. This can become an issue in certain homes- seams are not acceptable for most consumers particularly at that VLT. The 3M widths are 40/50/60 -this may or may not increase waste -depending on the window widths.
For accuracy sake on glass restrictions contact the 3M tech services people ; there you wll likely get a straight answer. (tintcousa @ May 24 2007, 09:54 AM) [*]509321[/*] Im looking specifically for solar absorbtion. Need to know if this film is safe for dualpane. Indpendent lab study specs would be ideal. 3m says it is but in the same breath say can not guarantee Why won't they warranty it? Or do you mean to say that won't guarantee it won't break? 3M rates NV-25 as safe for insulated glass unless certain other conditions are present (like the window is oversized, etc), so when you say they can't guarantee it -- do you mean that won't warranty it on a particular job or you are just hearing double speak. And when you say '3M' do you mean the lab or the 3M rep or the distributor or a local dealer? I use it all the time on insulated glass and haven't had problems with breakage. (are you a dealer or prospective customer?)
How many square feet per pane are these panes?
