tintdude.com logo
Advice regarding exterior application
uncle bob
Have been asked to look at some large windows on a car showroom. Approx sizes are 4 ft x 10 ft all double glazed laminated glass.
Have spoken to a couple of suppliers, they all recommend external application but offer differenet advice regarding the best product.
The main concern offered by 2 are that the absorbtion % should be below 40% even on external applications on laminated glass and it should be edge seeled with dow corning.
Another is advisind a product with an abs % of 49% !
Any advice from some of the experienced guys, please.
Bob
darkdan
The lower the better.
But if the company is willing to warranty it with whatever they recommend......
VO|TRON
you should see how much they warranty it for aswell as far as how much per pane. Most is 500.00 per pane and those panes will cost more then that if one has to be replaced. As far as an exterior application like dan said the less the better and yes you should seal the edges with dow corning 795 it will increase the life span of the film.
uncle bob
Thanks for the replies guys. Any supplier I speak to insists I inform the client of the risk "No matter what film is fitted to the laminated glass due to the nature of the product"
I am then informed that the panes in question are 8.8mm laminated and that any film can be fitted internally.
Any thoughts ?
Bob
blade
being a showroom, my guess is that they're tempered too....which means that yes, pretty much any film can be used. i wouldn't do an exterior application. definitely interior.
hoosierwindowtek
I don't think exterior film is a problem, I'd install it, but if they want an interior film, I'd definitely go with a low absorption film. A dual reflective, or silver or bronze film.
I'd stay away from a neutral film on those windows even if they wanted a 50% film, and I'd DEFINITELY stay away from some of the new "ceramic" films, since they seem to have pretty high absorption too. thumb.gif
vclimber
(blade @ Jun 8 2007, 01:16 PM) [*]513696[/*]
I agree. A car showroom would not look good with exterior film.
They could be Lami on both sides depending on the building code. I'd find out what that inside pane is before you do an interior installation. twocents.gif
uncle bob
As I said, regulations state laminated glass over 5 square mtrs must be 8.8mm and the sungard dealer ensures me I can install any interior film on that glass.
Will check wiith merlin lazer gauge to confirm glass make up.
Dealer suggests Nova 70 or 50%, good solar reduction without being too dark or reflective in appearance.
Bob
vclimber
(uncle bob @ Jun 8 2007, 01:56 PM) [*]513706[/*]
Bob
The Sun Guard rep can say whatever he wants but at the end of the day will Sun Guard warranty the window for glass breakage?
40sq ft piece of glass hmmmmmmm.gif I'd go with the 70% and make sure SG has your back.
Bulldog
(blade @ Jun 8 2007, 04:16 PM) [*]513696[/*]
If they have Heat strengthened or tempered laminated glass it will have alot more absorption tolerance. V-kool offers a couple of varieties if ya con tolerate the expense. Call and talk to Tom at 800SUN2Hot if you are interested....
ico_spam.gif ico_spam.gif lol
Solscreen
Hanita have a new film VLT of 70% Absorbtion 26% TSER 49% suitable for all glass, IDEAL FOR SHOP FRONTS..
Fitting external, nightmare springs to mind, one gust of wind, and theres goes another piece wasted.
Sol
TINT
i concur
personally i would do some cold steel 70 or even 50%.
that Sungard film Nova is very good heat blocking film, but i've seen the life span of that stuff i would not recommend. Like vclimb said, would they even cover any warranty on that??.
darkdan
(Solscreen @ Jun 8 2007, 11:32 PM) [*]513819[/*]
Sol
Which film is that?
Key West
blade
(Solscreen @ Jun 8 2007, 09:32 PM) [*]513819[/*]
vclimber
I'd probably look at Vista VS-60 at 58% TSER if the F2G result is acceptable. It won't be cheap though...
darkdan
(vclimber @ Jun 9 2007, 10:43 PM) [*]514210[/*]
Oh yeah, because anyone can buy Vista.
lilDetails
(TINT @ Jun 8 2007, 11:50 PM) [*]513840[/*]
i concur
I have Nova 35 on half my house. It has been on here for 4 years or a bit more. I did an office in town with Nova 50 about 6 years ago. I have one job that I did 8 years ago with Nova 50 that I see often.....
I have not seen any problems with any of those. I have only seen one time of a problem and it was an entry door that had a sign held up with suction cups. The film changed color in the circles where the suction cups were attached. I turned a film warranty claim on that one and got it replaced no problem.
So? I am not sure what you have seen or if it is just the less severe climate in Southern IL that is the factor.....but, I have had no issues with it.
vclimber
(darkdan @ Jun 9 2007, 08:56 PM) [*]514220[/*]
TINT
(lilDetails @ Jun 9 2007, 09:37 PM) [*]514234[/*]
probably differen climates in different parts of the country would be a big factor. im talking this stuff at a crown plaza hotel, with over 200 windows with that stuff already bubbled, and faded.
Solscreen
the new Hanita film would have a different european name called Spectra, 30 and 40,
The 40 spec absorbs 29, VLT 62 and TSER 57
vclimber
(TINT @ Jun 9 2007, 11:09 PM) [*]514256[/*]
About time they did something... what are you replacing it with?
(Solscreen @ Jun 10 2007, 03:53 AM) [*]514276[/*]
blade
TINT
(vclimber @ Jun 10 2007, 07:41 AM) [*]514320[/*]
Contact: tintdude[a]gmail.com
