tintdude.com logo
Film rolling off glass while cutting roll downs
darkdan
Recently I've been installing some 4 mil, 6 mil on cars and a little Llumar.
Man, I really cannot stand liner side in rolled film. It just tries to fall off the glass!
So I now cut out the driver's side window on the passenger side.
Then I cut out the passenger side on the driver's side.
Then I install both.
Works rather well unless you screw up the install and have to cut a second piece. Then you're back to square one and having it roll off the glass.
TintWizard
I've only ever had the occasional problem with it wanting to fall off the wall glass .Whenever I have a roll of film that's like that..after cutting the peice out on a rolldown door, when I go to bring it over to the wall glass, I simply reverse it and leave it there until it's ready to install, when it's time to install, I just turn it around again dunno.gif
I've never had a problem with not being able to control it while cutting it on the window since i'm right there working on it while doing so. I can see where that is a good tip if your having that problem orngbiggrin.gif
darkdan
I just hate having to try to hold the stupid thing in place while cutting.
Llumar isn't bad about in the summer, in the winter it can try to fall off a lot.
But 4 mil/6 mil is a different story. It's hard to keep it from rolling up while you're cutting.
kats2112
eyebrows.gif Hey I have an idea!
Since both doors are the simply opposites, just put the one that tries to roll off
up first then the other one will hold the first one up.
If yer not double cutting, yer wasting time and getting waterspots on both sides of the car.
Just be sure to tack the film down good, as it can slide during cutting! beer.gif
darkdan
Cutting 6 mil is hard enough. Double cutting 6 mil would suck.
kats2112
It's an acquired touch for sure. I have cut as many as 44 doors at one time.
took a while to line them all up, but after that , 22 trucks-- BAM BAM BAM !
We try lots of things. some fly, some flop. the important thing is to never stop
trying new things. That's how you develop your style to what works best for you! beer.gif
solarspot
(darkdan @ Jun 24 2007, 09:53 AM) [*]518480[/*]
I found this to work the best also I've done 5 trucks with N1040PS4
I didn't think about sharing good call DD
carolinatinter
there is a demand for safety film on vehicles where you are... seems worthless to me
darkdan
(carolinatinter @ Jun 24 2007, 01:06 PM) [*]518508[/*]
vzla-tint
I NEVER cut security film directly on the door/glass for 2 reasons:
1- The problem you have with the film trying to back roll, putting the film with the liner inside and cut the opposite side is a work around
2- You will NOT get a good cut this way, let alone, an appropiate cut for this type of film
This is how I do it:
- Take a piece of liner (actually we use tinted film) and cut the pattern, making sure you leave lot's of film downwards and left and right (by cutting one side, move the film towards that side so it overlapses an inch or so and then cut the other side).
- Use that pattern as a template and cut the security film with your knive or better yet, some sccisors.
- Install
darkdan
I'd imagine installing 15 mil like you guys do is a whole another ball game.
ssmobiletint
Hey Darkdan, can you shrink that stuff? Or have you guys been doing side windows with security film. Just curious, haven't done much security stuff. dunno.gif
darkdan
It shrinks, slowly.
You could do an easy back window with it, but I just use regular film on the back.
I haven't had to shrink a side window yet. Since it's thicker it compresses a little bit and small fingers will just squeegee down with no problem. Large fingers just wet shrink it.
Sadly, panel/gasket pulling is a must. =(
solar protect
(darkdan @ Jun 27 2007, 01:51 AM) [*]519230[/*]
I mannaged to sqeeze in 4 mil. film on the sides of Q7, but took off the spoiler for the better look of the b/g
But I guess thicker films are impossible to put on like that, even this was a challenge
darkdan
It can be done, but if you put a little crease on the side it can be very hard to get out.
vzla-tint
If you are serious about security film installation, it CAN'T be done!!!!
You MUST remember that a security film installation is very different from your normal tint job. The film MUST go deep into the frame to offer some sort of protection. There is NO WAY you can install a properly cut film without at least pulling the panels and gaskets.
solar protect
(darkdan @ Jun 27 2007, 02:09 PM) [*]519349[/*]
I thought that the pro's don't make creases nono.gif poking_someone_in_the_eye.gif
j/k
Dr.Window
Did my first auto S&S yesterday as part of a test, and guess what? Did all car with no prob!
Took all the pannels and rubbers out but not the windows, shrinked the BG ( slowly BTW ) and all went sweet!
It was 4 mil so not that hard IMO!
Tom Cat
I have been having tons of problems with the 3M colorstable (35% in particular) doing that especially pulling in a car in from the 100 degree weather. This is definitely a good solution beer.gif . Should have thought to post it.... wall.gif It could have possibly been my first TOTW!
dumplin
I had posted a tip on here once about using little magnets fron the hardware store to help hold the film while you cut , especially with the Llumar I use . The magnet works great and doesn't damage the film or the vehicle .
Key West
(vzla-tint @ Jun 27 2007, 02:48 PM) [*]519413[/*]
For a proper install, ya gotta anchor the bottom! Otherwise, it'll just PUSH out.
solarspot
(Key West @ Jul 6 2007, 06:31 AM) [*]521921[/*]
I agree and also think to get the best out of the film you would need to take the glass out. That being said I have quite a few friend in the construction business and smash and grabs are a very big deal to us. I had a friend lose $3500 worth of tools and he wanted something a little better than regular tint. I have said that it will only slow them down but sometimes making it a little harder to get in might save your stuff. I guess its just the idea and a little peace of mind to have a little more protection especially when you combine that with a good alarm. I have only done it for close friends and don't think I would market it to the general public twocents.gif
Bottom line if they want in their GONNA GET IN!!
darkdan
Even with an attachment system with enough beating they can push the window into the car. With an attachment system they wouldn't be able to pull it out very well.
One sided attachment just bends they have to fold it over.
Keep in mind, the idea is to deter, not stop with S&S film. If they want in, they'll get in.
But thieves are looking for the easy score. If they wanted to work for it, they wouldn't be stealing.
vzla-tint
I want to add that some cars don't have symetric windows. Did a Chevy Tahoe yesterday and the back windows are not the same, lost some material (2 x 15mil + tint) due to cutting the opposite side... mad3.gif
darkdan
Yeah, I noticed that one day.
I cut a piece for the passenger side and it was fine. Then I cut the same sized piece for the driver's side and it was short. I was like, "WTF?"
So I used that piece for a roll down. Then I cut another piece and it was wrong again!
Finally I measured BOTH sides and realized the glass is the same, but the black painted border makes the window much smaller on the passenger side.
I learnt something new that day.
tintinater
that's why you cut it big, so it doesn't matter if it's off a bit...
tintman237
(tintinater @ Jul 14 2007, 06:13 PM) [*]523987[/*]
hmmmmmmm.gif you must not do many GM SUV's, cuz if your cutting it big enough off the small side to cover the big side, you sure as hell ain't getting that piece to fit on the small side, but what do I know dunno.gif
willie
(tintman237 @ Jul 14 2007, 11:28 PM) [*]524016[/*]
excursion and some of the other suvs are the same
vzla-tint
Contact: tintdude[a]gmail.com
