tintdude.com logo
e-class merc back glass(6 times)
tintec
my very own new 2004 e320 first time tinting 1 of these,sides worked out perfect,but omg 6 attempts at the bg,small bubbles popping up so id heat them and rub them out but now there is dirty water marks left from where they were pushed out,i wire wooled heater bars the lot still not happy with it but ill have to live with i think,so frustrating makes u want to throw in the towel,although ive only being tinting a couple of months,did any of you go through this at the start?? dunno.gif
naughtydog
yep..we all go through it. Either continue or call it a day.
tintec
ill defo not be quitting,would a real pro get these small pop ups or would it rub out perfect 1st time for him?
willie
QUOTE (tintec @ Jun 25 2007, 04:09 PM) [*]518803[/*]
QUOTE (tintec @ Jun 25 2007, 04:15 PM) [*]518806[/*]
dude we all started in the same place with the same troubles
and theres no such thing as a perfect tint job, it just becomes easier and the jobs become better with practice and time
kats2112
beer.gif Just keep goin till u start having nightmares gasp.gif !
GodofWarII
bingo.gif not a very forgiving BG when it is frit to rubber on the bottom like that...i think i just smashed the BG with my PDR hammer thumb.gif
uncle bob
Keep at it, even the most experienced guys still have problems on glass they have tinted hundreds of times before with no probs.
I didn't have a grey hair in my head till I started tinting, now they're all grey
may the force be with you
Bob
tintec
thanks for the response guys,bottom isnt really my problem,its about half way up and about 2-3 inches in from sides i just keep getting these peanut pop ups when i heat and rub em out it leaves a dirty looking streak on the glass sweat.gif
naughtydog
QUOTE (uncle bob @ Jun 26 2007, 12:55 AM) [*]519029[/*]
Bob
No - your now just an old fart!
tintec
just thinking when i shrink my bg i would lay flat to the glass but i would have a couple of small bubbling when done shrinking would this be my problem,do you guys shrinking be as taught as cling film?
TINTZEUS
I'v done 1000's of these cars...I know what your talkin about.
steel wool the backglass....#0000...scrub it real good until all the high and rough edges are off the defrosters.
I would WET shape it...dry shaping .... nono.gif ... if you do it dry ....you will battle the bleaders. tantrum.gif
Happy Tinting
tintec
i did steel wool it,i always dry shrink,wet shaping just soak it with j&j soap and water, under and over the film and h anchor it is this correct?? gasp.gif
TINTZEUS
yep...seal the bottom edge ....and chase that bubble with the heat gun. after doing that I would trim the film, and re-heat the bottom edge..then cut the final pattern......this will result in having no fingers after the film is installed..... thumb.gif
I feel your pain....thoes older benz can be a pain in the buttox.... inot.gif
Contact: tintdude[a]gmail.com
