The front roll downs roll down about a 1/2" inch when open and when you close the door they roll up all the way. How did you work around this???
Fuse? Where is it?
G6 coupe front windows
Full Version: G6 coupe front windows
Ok guys, have a G6 coupe in here....
The front roll downs roll down about a 1/2" inch when open and when you close the door they roll up all the way. How did you work around this??? Fuse? Where is it?
trick the door latch
QUOTE (tintman237 @ Jul 28 2007, 07:39 AM) [*]527970[/*] trick the door latch How? QUOTE (tint45 @ Jul 28 2007, 07:41 AM) [*]527971[/*] Dont see any triggers or buttons in the dorr jam on this car.... ![]() Right on in there, push that latch a couple of times (either up or down, I don't remember) and it should "trick the window up. And don't shut that door till you've reset it!
use a bone stick and push the door trigger in. it usually takes 2 clicks to trigger the window.
sweet, you guys rock!!
Nope, havent tinted the new stangs yet. Remember, Im just a part-timer! QUOTE (tint45 @ Jul 28 2007, 07:41 AM) [*]527971[/*] Specificly, Blade's tip, if you can't trick the latch. that's a tip i learned here on tintdude.com. i can't claim it as 'my' tip. unfortunately though, i don't remember who's tip it was.
I've been using that trick for years. Started doing that on the old K series Blazers years back. Good Tip!!
QUOTE (TNTLady @ Jul 28 2007, 11:01 AM) [*]528007[/*] I've been using that trick for years. Started doing that on the old K series Blazers years back. Good Tip!!
same here
QUOTE (TNTLady @ Jul 28 2007, 11:01 AM) [*]528007[/*] I've been using that trick for years. Started doing that on the old K series Blazers years back. Good Tip!! I havent been around that long.... QUOTE (MidcoastMW @ Jul 28 2007, 04:17 PM) [*]528080[/*] I havent been around that long.... I've noticed So did you get - r - done? did it work QUOTE (TNTLady @ Jul 28 2007, 01:01 PM) [*]528007[/*] I've been using that trick for years. Started doing that on the old K series Blazers years back. Good Tip!! Not my favorite install there, not terribly hard, I just dont like doing them! QUOTE (tintman237 @ Jul 28 2007, 04:23 PM) [*]528085[/*] I've noticed So did you get - r - done? did it work It worked like a charm! Car came out sweet. Suntek HP-50 on the front, HP-5 on the rears. Heres a roll down pick, you guys saved my azz!!!!! ![]() I managed the b/g without pullng the deck, but I left alot more water than Id like under the film...
looks good...
shouldn't need to pull the decks on the G-6 or the G-5.....
QUOTE (lilDetails @ Jul 28 2007, 06:14 PM) [*]528161[/*] shouldn't need to pull the decks on the G-6 or the G-5..... I guess Im not that good then.
Bulldozer
Doors look good, Glad I could Help QUOTE (MidcoastMW @ Jul 28 2007, 07:44 PM) [*]528192[/*] I guess Im not that good then. Duh QUOTE (tintman237 @ Jul 28 2007, 07:45 PM) [*]528193[/*] Bulldozer Doors look good, Glad I could Help Duh
try getting a flatglass bulldozer, the ribbs on it are longer and alot less flexible IMO
http://www.44tools.com/merchant2/merchant....egory_Code=misc
glad i could help
