tintdude.com logo
Easiest way to cut Rear Window '07 F250 King Ranch?
Texasvdubz
What is the easiest way to cut the rear window on the 2007 F250 King Ranch? The back window is the type that the glass goes all the way to the HUGE rubber seal. NO ROOM FOR ERROR! I did the best I could and still had a tiny bit of light gap and the customer flipped! Any Help! hmmmmmmm.gif
SIR TINTSALOT
take it out
Texasvdubz
Oh yeah, I forgot to say it is the sliding back glass. How would you take it out? Or where can I go to learn how to?
Texastintchick
Texasvdubz
It is a 3 piece and is electric.
tintmann 313
on them first i tell custy that there might be a bit of a gap around his window and when his eyes get big i assure him that it will be uniform and look presentable. then i let him know why. [because of the hard edges.] then i have piece a bit big to lay and push water out all the window but only go about an inch away from edge. now take your nt red dot and bring blade to first click. notice that there isn't even enough blade there to even cut your finger? good then thats right...
okay now take that much blade and trim you window. this will take a bit of practice and make sure that your blade is really sharp [important] now with any luck you won't have a light gap but like i sad this takes practice so if you do have a light gap then just finish it like you would and then clean it heavy with alcahol and then get it really warm do the same to other side. then do your center. just gives more time for drying and now for the big secret... lock.gif film opaquer lol2.gif
yup thats my secret. i still keep a couple of them just in case but you practice this trimming method and you'll be like wow i'm the s**t
beer.gif good luck man...
umm what was we talking about again....
losdawg
some thing that I have been doing lately on trucks like that is, I use moleskin around the edge. I have the stuff that is cut into 1/4 inch strips and I just lay around the edge where I get that gap. It works great for me...mabey TOTW dunno.gif
SIR TINTSALOT
Bundy Bear
Limo Tint Larry
You can trim the hard rubber plastic crap. I just did one and it turned out fine no gaps. its only that one section of the glass that needs it anyhow. The outer corner from top to bottom.
Mr paladin
I like to use a red dot on those for the smallest light gap possible orngbiggrin.gif some people put a small bead of black silicone around the edge dunno.gif
autoez22
cut it on the outside, trim the inside rubber CARFULLY, and install. ive never had an issue with the hard rubber
GeneralTint
Did one yesterday, heat the inside hard plastic thing that is tight against the window ALITTLE, then trim it. It worked well for me, took my time and trimmed cleanly, and it came out with NO light gap. I do not like the film opeque pen, it looks like SHIZZ if you ask me.
Why the hell does Ford have to continue with these stupid back windows? To make us krazy.gif .
willie
QUOTE (b_faulk75 @ Sep 2 2007, 08:38 AM) [*]540304[/*]
OSU Pike
I always just carefully trimmed out some of that hard gasket...Always works really well for me, cut it on the inside..and whatever gap if any it left paint pen it... ;)
true-tinter
QUOTE (SIR TINTSALOT @ Aug 15 2007, 03:32 PM) [*]534900[/*]
take it out
It will dry...
Gee we are lucky in Aust. They are just one piece of glass so its nice and easy dunno.gif
ROCCO
WORKING ON 2007 F-250 X-CAB WITH 3 PICE POWER WINDOW I AM NEW BUT THIS ONE IS HARDER THEN MOST REAR WINDOW'S ANY HELP WOULD BE GREAT THANK YOU ROCCO FROM KEY WEST FL VROCCOB1@AOL.COM
ClassOnGlass
if the custy dont want it trimmed use small black pinstripe tape to cover the small light gap thumb.gif
thatsnappyguy
i usually over cut it, and trim on the inside after its stuck. works ever time.
allprotinter
QUOTE (thatsnappyguy @ Jan 27 2008, 08:55 AM) [*]585513[/*]
Mdog
QUOTE
Thats the way i do it also. You really dont get any light gap that way. trimming the plastic is doable.
Clark Tint
I found the easiest way for me was to heat up a wide putty knife with high setting on my heat gun and create a small tuck under the incapsulation on those sliders no gaps and comes out perfect every time. i think tint general has a similar technique. orngbiggrin.gif
big money
QUOTE (Mdog @ Jan 27 2008, 06:27 PM) [*]585669[/*]
QUOTE
1PEECBARETTA
spray paint and duct tape works for me.
Contact: tintdude[a]gmail.com
