tintdude.com logo
Anyone able to tell me how to drop bmw 740 panels?
DezilDoesIt
my brother just purchased a 2001 Bmw 740 and I looked it over to tint and only saw one screw in the door handle cup are there any more hidden screws or does the rest just held in by clips? I ran into problems tucking film under tight gaskets.
Shady Sherlock
Olfablade
Carefully tuck the gaskets, and then pull them up after film install. No need to remove panels. thumb.gif
Bundy Bear
They are a real biatch to remove. The plastic strip that runs across the door panel comes off and there is two star bolts, then there is one in behind the air bag badge and one in the handle and a couple underneath. You can do as Olfa said or just take out the start bolts, pop the top of the door trim back and remove the gasket. You probably should take it to a BMW dealer and ask them to show you dunno.gif
DezilDoesIt
Thanks B Bear
tintman237
no need to pull da panels on those, just pull the rubbers out twocents.gif once you pull one panel, you'll see how the rubbers come out, evilgrin.gif easy peasy beer.gif
Bundy Bear
(tintman237 @ Sep 17 2007, 01:40 PM) [*]545308[/*]
Is there a freakin echo in here?
Litespeeds
You do not have to remove the entire door panel. All you need to do for the front door is to remove 1 screw inside the vent area and then with the window rolled down, pull back on the top section of the door panel and then use a hook tool to remove the door trim and clips. Put the clips back on and tint the glass. With the window down, carefully put the trim back into place and that is it. All BMW door panels are built like that.
I think I have it on one of the Tip of the Weeks a long time ago. If I find it, I will post the link. Good luck.
http://www.tintdude.com/totw54.html
Contact: tintdude[a]gmail.com
