07 Corolla quarter windows
Full Version: 07 Corolla quarter windows
I actually tried to take out those pesky little rear door quarter glass windows today, i removed the upper hidden screw, then the one behind the panel, but i could not get the window track that runs in front of the quarter to move enough to get it out. This rear window track runs all the way to the bottom of the door, i even removed the lower bolt on the track, but it still wouldn't come completely out. Do you guys take this rear window track out? If so do you remove the roll up glass first, i got scurred of breaking things so i just put it back together and did the best i could with those little windows, but i still want to be able to remove them to do a proper job.
Brother no need to remove those 1/4glass..
change the soap water ratio(for positioning) And use your bone around the inner rubber seal. Tack and extract.Done!
That's how i always do it, but no matter how carful i am i end up getting some contamination or worse, small little creases around the edge of the film. I hate it personally and would like to be the place that does em right. Kind of a trademark, if those windows look like crap you will know i didn't do it, if they look factory, you will know i did. But thanks for the reply.
Just curious?But do you razor then totaly clean the 1/4glass inner seal with a bone coverd by a towle..Then intsall.Of course flush with garden hose?jkjkjkj
Today i razored, shoved my bone in there
clean the 1/4 really well. I use a yellow condom wrapper to clean it, come out real clean man. i havent had any dirt.
03 h acrd..Cool.
Sedan or coupe?You did say you'd remove 1/4rs if nssry.And it is. You'll have a better day then..For sure!~ (GeneralTint @ Sep 21 2007, 08:07 PM) [*]546933[/*] Today i razored, shoved my bone in there first off...try a micro fiber cloth instead of paper towel...works wonders...and second...the creases should heat out with a chizler. (one slick tinter @ Sep 21 2007, 05:26 PM) [*]546956[/*] first off...try a micro fiber cloth instead of paper towel...works wonders...and second...the creases should heat out with a chizler. chizzler takes time if theres alot of creases,,,start fresh (one slick tinter @ Sep 21 2007, 07:26 PM) [*]546956[/*] first off...try a micro fiber cloth instead of paper towel...works wonders...and second...the creases should heat out with a chizler. I'll try a microfiber, the creases do come out for the most part, but they are still a pain. Does anyone remove those windows? (banfam55 @ Sep 21 2007, 07:10 PM) [*]546948[/*] 03 h acrd..Cool. Sedan or coupe?You did say you'd remove 1/4rs if nssry.And it is. You'll have a better day then..For sure!~ Do you mean, take them out?
i dont take out the 1/4's on the corolla's..on the 4 door accords with the tuff 1/4 yes
theses ones...the 2008 accords (4 door) you dont have to take the 1/4's out
never had to take out any corolla windows before
(SIR TINTSALOT @ Sep 21 2007, 10:52 PM) [*]547133[/*] never had to take out any corolla windows before lol thats what iam saying, i thought i read the thread wrong,,,1st time for everything, right?
Are you using a thin non reflective film?
Maybe a thicker HP film with more backbone would help you when sliding those quarters. (MarcoLb55 @ Sep 22 2007, 02:26 AM) [*]547142[/*] lol thats what iam saying, i thought i read the thread wrong,,,1st time for everything, right? Are you tryin to make fun of me there LB, your alter ego banfam seems to be very helpful, why don't you reply as him (naughtydog @ Sep 22 2007, 03:31 AM) [*]547148[/*] Are you using a thin non reflective film? Using carbon.
Maybe a thicker HP film with more backbone would help you when sliding those quarters. (GeneralTint @ Sep 22 2007, 05:33 AM) [*]547165[/*] Are you tryin to make fun of me there LB, your alter ego banfam seems to be very helpful, why don't you reply as him Using carbon. GENERAL TINT, come on man. i wasnt making fun of you at all. Dont be upset.
I did remove the quarters on the accord i did today and it came out great, not related to the topic but just thought i would share.
cool man. I am happy it worked out for you bud
I don't remove the quarters on the corolla either enough slip and they do slip up inside and my over cut is only 1/8 th around
