use the window snapping method to roll or curle ur edge lightly on the top and bottom it will allow the tint to fit the window like a glove and prevent any unwanted fingers works very well and it seems to make it stick better on the dot matrix....
over shrinking your rear window
when ur done shrinking out ur rear window....
i tried it just a lil bit ago. didnt work for me. every where i snapped...i had to catch it with some heat after the install.
I've been telling people to do this for a while.
Personally, I just wet the bottom and top and force up a few extra fingers. QUOTE (darkdan @ Oct 10 2007, 04:55 PM) [*]552871[/*] I've been telling people to do this for a while. Personally, I just wet the bottom and top and force up a few extra fingers. thats called a wet check, might as well wet the whole thing and squegee out so its all nice and flat then when you make all your cuts makes it easier to see. QUOTE (ClassOnGlass @ Sep 22 2007, 05:41 PM) [*]547297[/*] when ur done shrinking out ur rear window.... use the window snapping method to roll or curle ur edge lightly on the top and bottom it will allow the tint to fit the window like a glove and prevent any unwanted fingers works very well and it seems to make it stick better on the dot matrix.... I personaly like a different format that is very efficiant An open flame tech click below on this caddy 07 http://www.youtube.com/watch?v=5m8LPaK-x-g QUOTE (thatsnappyguy @ Oct 10 2007, 05:00 PM) [*]552822[/*] i tried it just a lil bit ago. didnt work for me. every where i snapped...i had to catch it with some heat after the install. not where you snap shrink......you have to snap shrink the whole edge roll the entire edge top and bottom just a slight roll small cure it work awesome try it let me know QUOTE (Sprinter @ Oct 11 2007, 09:26 AM) [*]552969[/*] thats called a wet check, might as well wet the whole thing and squegee out so its all nice and flat then when you make all your cuts makes it easier to see. A wet check just checks fit. Which if you dry shrank and smoothed it then it should fit. I'm talking about purposely forcing up extra fingers to shrink them.
I thought mom was 5'2"
QUOTE (darkdan @ Oct 21 2007, 04:49 PM) [*]555641[/*] A wet check just checks fit. Which if you dry shrank and smoothed it then it should fit. I'm talking about purposely forcing up extra fingers to shrink them. if you ever snap shrunk its totally different from a wet check when you snap it adds a curve to the tint #1 and when you install it with a curve to the shrink it cling to the glass extra tight #2 so it is not a wet check get it got it good
wasn't this already covered a few months ago by mdog or someone, complete with video demonstration?
QUOTE (darrin1 @ Oct 22 2007, 12:23 PM) [*]555854[/*] wasn't this already covered a few months ago by mdog or someone, complete with video demonstration? This one?
I'm well aware of what snap shrinking is, I've been doing it on side windows for well over a year and a half now.
now I know in part; but then shall I know even as also I am known. © 1999 - 2008 Ric Wellman All Rights Reserved. Contact: tintdude[a]gmail.com | |
