tintdude.com logo
prius ?
Full Version: prius ?
bgtint
I have a Toyota prius. Can any one tell me how to remove the rear windshield wiper and isn't not as easy as removing the bolt underneath the plastic cover because when you try to pull out the wiper it does ant want to come off.
tintman237
once you have the nut removed under the plastic cover, push down on the wiper where it has the piviot in it, and pull up on the base (where you removed the nut from)
dunno.gif why are you removing it? I do alot of prius for my toyota dealer, and you can lay the film right under the wiper, no problem.
bgtint
I never thought if it that way. This is the first car tinting in a underground parking garage.
tintman237
this is your first car your tinting, or it's your first time tinting in an underground park garage dunno.gif
either way, prius is an easy car to do. that back window reqires very little shrinking, cut the doors a little big, or you'll have light gaps, other than that, no problems.
Good Luck with your adventure.
TINTZEUS
QUOTE (tintman237 @ Sep 22 2007, 07:19 PM) [*]547320[/*]
bgtint
This is the first car I am tinting and because I don't have a garage this is the only place I can come up with that suits a tinter's needs.
Contact: tintdude[a]gmail.com
