tintdude.com logo
toyota colorado landcruiser
BLACKOUT TINTS
Hi did one on these on a y reg 2001 limo tint for the rear end and 75% for the front although the rear screen is flat glass i would still recomend shrinking on the out side i did a wet shrink the spare wheel comes in the way but i managed the side panels on dont have to be removed as you can use a gasket jamer or you can pull the panel up and this will give you more room to get the tint to slide in same with the front widows pull on the panels so it lifts but be gentle hope this helps
good luck
mas
Contact: tintdude[a]gmail.com
