Dry shrinked - is this how it should look like once shrinked?[u]
Flat with wet check shrink on right side
Completed, but small tiny bubbles show
Anyway what do you think?
Vauxhall Vectra 1 piece completed but tiny bubbles!
Full Version: Vauxhall Vectra 1 piece completed but tiny bubbles!
Did a dry shrink by using Dart filmz, what do you think? I am improving there were some big fingers,
![]() Dry shrinked - is this how it should look like once shrinked?[u] ![]() Flat with wet check shrink on right side ![]() Completed, but small tiny bubbles show ![]() Anyway what do you think? ![]() Good job..man
dude, I think I see baby powder... dump that stuff an git wit the MDOG soap shrink mang!
You def got shrinkin down, the install doesnt look bad... keep pluggin as willie says mang! Look into the soap shrink its that important. Its all over dis place like a mug.
looks good...but i think you need a little more baby powder on there..
http://www.youtube.com/watch?v=3Kdc4h0P8js
Check this out above brother!!click the link!!
Cheers dude, can i use any soap?
So clean the window outside and then use soap over the window, make a H anchor and then apply film locking the sides. Is this right? What makes it so different to the powder methood? QUOTE (Samrasr @ Oct 11 2007, 12:32 PM) [*]553040[/*] Cheers dude, can i use any soap? So clean the window outside and then use soap over the window, make a H anchor and then apply film locking the sides. Is this right? What makes it so different to the powder methood? well for one the car and the tint aint covered in damn baby powder! Ivory soap is my fav, I put it in a sock (also handy for beatin mehicans) wet the rear glass, apply a layer of soap (I try to keep it on the drier side) wait for the glass to be 100% dry, lay your film anchor it and start shrinking. It allows you to hit much larger areas quickly instead of the large fingers you see in your 1st picture. Its more of a "surface shrink" I did it forever too wet and then let it really dry out once. It shrinks quickly and there is no mess, a bar of soap lasts ages too. Also remember handy for beatin mehicans QUOTE (banfam55 @ Oct 11 2007, 08:57 PM) [*]553028[/*] Good job..man Good job Try tinting indoors for a better result QUOTE (Diamond Tints @ Oct 11 2007, 02:07 PM) [*]553048[/*] Good job Try tinting indoors for a better result
QUOTE (BIG E @ Oct 11 2007, 04:02 PM) [*]553087[/*] handy for beatin mehicans
Why was I not surprised to see a torch in that vid ?
QUOTE (tint123 @ Oct 11 2007, 04:14 PM) [*]553089[/*] Why was I not surprised to see a torch in that vid ? Because nothing surprises you
I use to try to be the fastest tinter, but that was when I worked for somebody and was trying to make the money as fast as possible cause I was only getting a % of the job, but after owning my own biz for a few years I guess I got used to having employees, cause I seem to move hella slow these days. I can still do a whole 4 door in an hour and a half though.
