tintdude.com logo
07? or 08? A3
Full Version: 07? or 08? A3
theonlyangelica
how do you remove the panels on these? Has anyone ever done on of these? Any problems or tips you could give me would help. Thanks!
pro_tinter
I done an 04 plate a week ago and I think its still the same same in the 07 reg. I usually pull panels but on these you can pull pack the top of the panel that meets the window. Then using a hook tool or even long-nosed pliers you can lever out the rubber seal, which gives you enough to tuck the film.
Use a pry tool or a screwdriver wrapped in paper tower about 3 inches to pop the clips that are located either side on the upper section of the panel, makes pulling that rubber thing out alot easier. Spray a little WD-40 if it dont slide it back in with ease! orngbiggrin.gif
My concern is the tight felt edge, what card do you use to get the film right in there?? Its doin my nut in now! mad3.gif
Contact: tintdude[a]gmail.com
