tintdude.com logo
2006 mercedes ml advice
tintec
got 1 coming on tuesday,any tips ive being reading here that the b/g explodes easy when you heat it,im worrying now,any advice guys? uh.gif
losdawg
Just take your time. If the back window is laminated I would avoid putting too much heat on it. If my memory severs me right that back window is not laminated tho. beer.gif
goldtooth
QUOTE (losdawg @ Nov 19 2007, 06:18 AM) [*]563879[/*]
beer.gif take your time,i dry shrink them,never had a problem..not sure if the bg is lam,but you really dont need excessive heat .. thumb.gif
DukeofTint
the ml is not a hard tint the back window takes the most time.
tintec
thanks guys,ill shrink it slow on a low heat setting,my main worry was them merc defroster lines can be pretty thick so when the peanuts start popping up it takes a lot of heat to get em out
naughtydog
wire wool the backglass with 0000 wire wool.
Dont heat the %&$# out of the matrix like diamond tints did...just tell the customer there may be a little silvering on the matrix and save yourself some ££££
tintec
i dont mind the matrix silvering,ill try the steelwool does it really help prevent them pop ups?
naughtydog
If you shrink it correctly it will be fine...the wire wool just removes the laquer layer from the heater line, it works for me.
I find soap shrinking to be the best.
what type of film are you using?
tintec
i soap shrink also and i use johnsons greystone but on limo i use rayguard johnsons as theres no limo in greystone,thanks mate ill give the wool a go,a quick once over or do you really have to scrub it?
ClassOnGlass
mas
I once had a wierd situation with my uncles 2000 ml the stock stereo didnt work, no sound and i check all the wiring and fuses and found out that the stock radio wans't powering the remote wire that turns on the factory amp. What I did to get it to work was tap the ignition wire to turn on the factory amp and it worked. About and hour later after we ate dinner and came outside and there was the bg in pieces. Now my uncle calls insurance and they replace it with a new bg and the thing exploded again. So now my uncle told me to undo the wiring and it never happened again, my uncle didnt blame me because it just not logicall that something like the radio would be tied into the bg in any way. Just thought I share this story.
goldtooth
QUOTE (mas @ Nov 20 2007, 10:26 AM) [*]564176[/*]
beer.gif good to know ,tinted allot of them never had problems,thanks for the heads up thumb.gif
naughtydog
QUOTE (tintec @ Nov 19 2007, 02:40 PM) [*]563940[/*]
Just give it a good rub all over, i do it after I have scrubbed the backglass.
tintec
got the car done b/g was no probs at all,dont know what i was worrying about!then just my luck on my last window i was cutting pattern on outside when i realised that i had just cut straight through the rubber gasket on to the glass leaving about an inch still in tact top and bottom,i used superglue to stick it back,hope customer doesnt realise,did anyone else ever make this mistake on a mercedes?? dunno.gif
naughtydog
QUOTE (tintec @ Nov 29 2007, 01:53 PM) [*]566907[/*]
tintec
if he noticed this,would it be possible to get gasket replaced or would it be a new door?? gasp.gif
Contact: tintdude[a]gmail.com
