tintdude.com logo
A tip for cutting the correct amount off the roll...
Exact-Oh
I have been tinting for years, and until before a couple of months ago, I would still struggle with this one:
In the past I would measure the horizontal dimension on the roll-down, and estimate how much to add to the base dimension for the angled rear edge. Sometimes, it would still come up short in the upper-rear corner, then I would have to cut another piece off the roll, wasting some film in the process. Granted, I could still use the first piece for a rear roll-down or something, but it was annoying.
Here's a tip that I have been trying out for the last couple of months to stop that from happening:
Basically, I measure the base of the roll-down window, then measure the diagonal dimension from the upper-rear corner to the lower-front corner. I would then divide the difference of those two measurements in half, and add that to the first base measurement. For those of you that like to add 1/4" extra behind the gaskets, add another 1/2" (front and rear tuck).
Example: Measure the base dimension, for instance, 32". Then measure the diagonal measurement, or 37". The difference is 5", so I add 2.5" to the original measurement, 32" + 2.5" = 34.5". I like to tuck 1/4" on both sides, so I cut 35" off the roll.
I haven't been tinting as much as in the past, only doing it part-time now, but I have tested this formula on about twenty vehicles in the last couple of months, and it works slick every time. I don't have to cut it again, longer, and I don't have waste.
zolar
TTS
willie
Nice one, and good to see you around Exacto oh. Hope everything is going well for you thumb.gif
TintDude
TITAN500
thumb.gif good tip zacto
ClassOnGlass
nicey nice bro
mas
QUOTE (Exact-Oh @ Dec 26 2007, 10:03 AM) [*]574425[/*]
Sorry i dont understand what your trying to say. Can someone explain it to me. Thanks
CajunTinter
solareclipseauto
Key West
QUOTE (ClassOnGlass @ Dec 26 2007, 09:25 PM) [*]574517[/*]
nicey nice bro
That would be "NIcey nice, SIS!"
QUOTE (CajunTinter @ Dec 26 2007, 11:19 PM) [*]574537[/*]
Dudette!!
Wassup Exact-Oh. Long time no see. How's things? Glad to see ya!
willie
QUOTE (Key West @ Dec 27 2007, 02:27 AM) [*]574553[/*]
Dudette!!
tinterjim
lilDetails
I have checked a few doors the last couple days and I find that I would be shorter than I like with this technique.
I just put the tape along the bottom seal and then bend it at a 90 degree up so that have a good idea of the distance....has not failed me once in the few years I have been doing it.
CleanCutter
is it just not easier to take the roll out of the box and roll the film directly out onto the window and cut off just what you need?????? flip roll over... bingo, now you're double cutting. Unless you're using a 40" roll for sides or something, seems like a lot of extra work for something that takes about 8 seconds. By the time you get the math done, I've got film layed out and ready to trim for 4+ panes.
darkdan
That's how I used to do it. Measure it like a TV.
Nowadays, I just stock 20" rolls. =)
willie
QUOTE (darkdan @ Dec 31 2007, 10:16 AM) [*]575281[/*]
CajunTinter
Maybe he only tints trucks now... dunno.gif dunno.gif dunno.gif poking_someone_in_the_eye.gif
willie
QUOTE (CajunTinter @ Dec 31 2007, 06:45 PM) [*]575405[/*]
he must have sold the crown vic and aspire then. I though they got retinted once a month poking_someone_in_the_eye.gif lol2.gif
willie
QUOTE (willie @ Dec 31 2007, 06:58 PM) [*]575417[/*]
my bad a 20" will do a crown vic. Ive never had the pleasure of an aspire rollin.gif
tintman237
QUOTE (willie @ Dec 31 2007, 05:59 PM) [*]575419[/*]
willie
QUOTE (tintman237 @ Dec 31 2007, 07:00 PM) [*]575420[/*]
tintman237
4 door anyway
willie
QUOTE (tintman237 @ Dec 31 2007, 07:06 PM) [*]575426[/*]
4 door anyway
thumb.gif yup the 24 inch is just a harold short
darkdan
I don't mean I stock only 20" rolls I mean nowadays instead of slicing films I also stock 20" rolls.
Exact-Oh
Thanks for all the 'welcome back' messages everyone. Things have been fun and profitable in the engineering world.
In regards to the tip, I tested it and it does work, and I can do the math in my head before I get to the cutting table. I'm sure there are a few cars out there that it will fail on, but that's life. No two cars can be tinted exactly the same. All of the vehicles that I have tested it on so far have worked flawlessly using this method.
I stock only 36" rolls, and for most cars I cut just that one calculated length off the roll to cover both sides (if each side is <18" tall).
gramma
I use a carpenters square if the angle looks to tricky. tape it up with masking tape so you dont scratch the car. lay it on the bottom edge and move it over till the verticle side is where it needs to be. use china marker or what ever u like to mark on the horizontal then measure. cant go wrong. its allways better to over cut than under cut from a picky tinters point of view.
FilmBlazer
tuttle
i fixed that prob years ago. we all use a 12" square that also dubbles for a 18" strate edge, ad tocut our holes for the buttons on the vent windows. take that square and put it in the corner and take your tape measure and measure the the distance at the top and add to the bottom, and give your self 2" for extra room and bam. no more wast. no problems and start saving your film from being to short
Contact: tintdude[a]gmail.com
